Plenum spacers: Do you need a tune afterwards?
Not needed yet....!
dankl, you won't need a tune until you've made many more mods. If you're
installing the MotorDyne spacer (which you should) the instructions will tell
you to remove the negative side of the battery while doing the install. Simular
to the instructions for installing an intake....that should do the trick. (for now)
Gary
Gary
Thanks guys. I'm new to these cars and motors. I was just talking to my mechanic before and he said I may need a tune if I do the spacer. I figured there was a lot of good knowledge on this website from people who have "been there and done that".
I was thinking of doing a CAI, a cat-back, and the MREV2 and spacer, or some kind of spacer combination for my Rev-Up '06 engine. Any good advice to save me hours of research?
Thanks again all.
Thanks again all.
Thanks again all.
Thanks again all.
MotorDyne is the only one I'd go to for their MREV2 & 5/16" spacer. Intakes,
you need a Z-Tube and I'd go with Stillens CAI or just the K&N drop in filter....
your choice. Popup chargers look great but suffer from heat soak which kills
HP....who needs that? Cat-back exhaust, so many choices....and I've run
most of them....Ouch$$ For sound, quality and HP gains there's only 2 I'd
consider HKS and Stillen. Both systems are real dual systems for maximum
flo. Happy Modding....Gary
Very good points/suggestion by all. I guess the MREV2/spacer combo needing a tune is a good question. Seems like the tune is not required, however, is always a good idea when changing air flow to your engine.
I was thinking about a CAI for sound, not just performance. I wanna keep this car sounding nice and clean, so an intake and a great sounding cat-back, mixed with the MREV2/spacer should be what I need.
I already have a beast of a car, so I'm not looking to get every last pony out of the G. This is now my daily driver, but it is a little too quiet for me stock.
