| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Noise on HFC install
Hey guys so i just put in some in some kinetix HFC but i just noticed im getting a weird noise around the 2300k RPM. It sounds more like a little rattling im guessing rasp? sound. I have a magnaflow exhaust and 1/2" spacer and the Kinetix HFCs. I also have an AT coupe. If you guys can give me just a heads up whats prob wrong or if its just normal rasp?
__________________
'03 DP coupe with some MODS |
Sounds like you have an exhaust leak...gasket or something leaking at a joint is my guess.
Although, with cats (if they are used) sometimes they can blow out and you will have rattling.
__________________
Stillen Airbox | JWT Popcharger | Z-Tube | UR Light Crank Pulley | E-Fan | Catch Can | GG 10 Wire | MD Copper 1/2" Spacer | TB Spacer | Kinetix HFC | MD XYZ + VQ Resonated | Stillen Engine Damper | SPC Rear Camber | Stillen Sways | CircuitSport Tie Brace | 350Z Suspension |
^^^+1
__________________
2004 IP COUPE 6MT - JWT Pop Charger + Z-Tube / TopSpeed Pro-1 Exhaust |
I also have the 5AT and have drone around 1600-2000 rpm's but drone is a lot different than a rattle.
Did you do the install yourself or have a shop do it? Either way check all the bolts to ensure they are snug and your exhaust is not rattling/hitting anything under the car.
__________________
For sale: Borla cat back, Berk HFC's, 3" MAF/filter. |
I bet its like vrrooooommmmm psssssttttttttt
Its a common issue with test pipes and HFCs on our exhaust. Do a search. There are countless threads about it. Basically its the sounds of the gases flowing through the exhaust which our cats usually muffle. When you remove the cats more gases flow through the exhaust and you have the hissing sound. My stock exhaust + HR Y pipe combo gained hiss sounds when I added my Berk HFCs. When I eventually switched to FI Intimidator exhaust, the hiss went away.
__________________
05: IP G35 Coupe Sport: *Phase IIin Full Effect!* |
does it sound like my car? ^ if it does then its the heat shield, i also just had kinetix HFCs installed, and my heat shield is getting either cut or completely removed next week.
__________________
2005 Athens Blue G35 Coupe: 6spd | Injen CAI | Kinetix HFC | LEDs |15% Tint |
it sounds like yours but your last from like 2200-4k. Mine only lates from like 2300-2500...You still think it may be the heat shield? Actually it can also be my gaskets i will check it once again actually....
__________________
on my car it doesnt seem to matter what RPM im at, it seems the faster i accelerate the more it rattles. if i accelerate slowly then it wont do it no matter what RPM im at, even when im stopped and i rev it i cant here it rattling...so it being the heatshiled made sense to me because depending on how fast the acceleration is the greater the force is pushing the heatshield back towards the HFC which makes a rattling sound.
__________________
hmmm idk about mine than. yeah when i push it hard than it passes by the rattle area and cant hear it and only happens usually on the down shift when i hear it the most...Im clueless about my problem than. I'm guessing its the gaskets than?
__________________
hm mine does that too after a test pipe install, as well as the hiss. but my rattle lasts from like 2500 rpm to like... 4 or 5k. ill try to get a vid, maybe its the same thing?
ive redone (at least the lower) gaskets on mine, and retightned the bolts. and had it at a muffler shop for a few hours. they couldnt find anything :/
__________________
05X|LEDs|Crawford|HKS|Testpipes|BC Racing |Passport SR7|HID Fogs|Rookie Bumper |
damn i was plannig to get kinetix hfc but two people have rattling noises just in one thread
i broght mine back to the shop that installed it, and they just bent the heatshield a little and now the rattle is all gone...sounds great now
__________________
| Tags |
| 2000, accelerate, berk, charger, flow, g35, g35x, heat, hfcs, infiniti, noise, rattle, rattling, rpms, shield, whats |
| Thread Tools | |
| Display Modes | Rate This Thread |
