Y-pipes for AWD sedans
Old 09-11-2013, 09:07 AM
yosip1115's Avatar
Originally Posted by RXM
They already shipped it out and it should be here by today (NJ to PA). This is a direct OEM replacement so I'm thinking everything should bolt up nicely. I'm f'in tired of hearing the rattle. Oddly enough, the sound goes away when I turn up the radio
My OEM pipe rattled to the point where it was embarrassing. Not even 1 year later my m2 does the same.
I'm probably going to modify a bosal brand pipe because I don't want to lose my 3" outlet diameter... I have a 3" catback to match up to. I hope the bosal brand one is made out of better materials... It seems to be, it's not as shiny as m2's was.
  #77
Old 09-11-2013, 02:58 PM
RXM's Avatar
RXM
RXM is offline
Bosal makes a lot of oem parts so I would think that they could put together a quality, albiet ugly, y-pipe.
  #78
Old 10-01-2013, 11:41 PM
seddon's Avatar
Does stillen still carry the exhaust for the awd sedan?
  #79
Old 10-25-2013, 09:24 PM
Gman56's Avatar
Im new to Infiniti. What is the benefit changing the y pipe? Do you gain more hp? I have an 05x.
  #80
Old 10-25-2013, 09:33 PM
yosip1115's Avatar
Not much hp to gain there for your specific car
  #81
Old 10-25-2013, 10:40 PM
Gman56's Avatar
Thanks. I guess little gain not worth the cost.
  #82
Old 10-25-2013, 10:44 PM
yosip1115's Avatar
You should get high flow cats and a tune. A k&n drop in filter helps also from what I hear. I do not recommend the m2 y pipe for our car. I'm not sure which other ones will fit it however. There is a thread about it. I also love my lightweight pulleys, they don't require a tune!
  #83
Old 03-09-2015, 03:38 PM
jjpG35x's Avatar
Originally Posted by tknobby81
2004. also have Kinetix HFC's, Magnaflow straight thru for a mid and Magnaflow straight thru for a rear.
Attachment 158167
Hey, sorry to bring this old tread up. I'm shopping for kinetix hfcs but I keep getting told that they won't fit the awd Gs. Any ideas?
  #84
Old 10-21-2015, 02:50 PM
bcertified's Avatar
I just installed kinetix HFC's on my 05x AWD at a muffler shop fit directly on, has some rasp though. But it does give it a better growl some when you start it up.
  #85
Old 04-04-2016, 01:38 PM
El_Donks's Avatar
Is there a thread like this specifically for the 2nd Gen G35x?
I am trying desperately to order a Megan Y-Pipe but have no idea which model is needed, since I have heard people say that both will work? Various sites have conflicting information on this, some say it will fit AWD and others say RWD drive only. At a loss here and the manufacturer has not responded...
http://www.meganracing.com/product.asp?prodid=298 - MR-Y-N3Z-V2
http://www.meganracing.com/product.asp?prodid=1071 - MR-Y-PIPE-N7Z
Which is it?
  #86
Old 04-04-2016, 02:05 PM
RicoG35x's Avatar
Go with the VQ35DE Y-Pipe...
  #87
Old 04-04-2016, 02:35 PM
El_Donks's Avatar
I assume you mean the revised DE (now HR) pipe for the G35? MR-Y-N3Z-V2?
Edit: Confirmed that part# MR-Y-PIPE-N7Z is needed for Second Gen G35 vehicles, with the manufacturer.
  #88
Old 04-17-2016, 11:54 PM
3000vr4tt's Avatar
so i got an 05x would you guys suggest getting the m2 performance for 08g37?
  #89
Old 04-18-2016, 11:27 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
Won't fit, sorry.
  #90
Old 05-02-2016, 06:39 PM
The_Silencer's Avatar
Anyone knows if this y pipe fits the 05 G35x? Says the oulet is 3". Does outlet diameter make a difference?
Quick Reply: Y-pipes for AWD sedans
