Best Drop In Air Filter
This is old, but is shows that "rechargeable" air filters, flow more air, but don't get the dirt out.
http://www.bobistheoilguy.com/air-fi...ltration-test/
If I had it to do all over again, I would leave the OEM air box, replace the tube and stick with a good NON RECARGABLE air filter. No K&N or the like ever again.
This is old, but is shows that "rechargeable" air filters, flow more air, but don't get the dirt out. http://www.bobistheoilguy.com/air-fi...ltration-test/ If I had it to do all over again, I would leave the OEM air box, replace the tube and stick with a good NON RECARGABLE air filter. No K&N or the like ever again.
So what? I was using the search to find a good air filter. This thread had good info and i saw the apexi air filters on conceptz. Instead of being a Dick you could of moved on to the next post. But thanks for sharing that helpful information
Air filters are also a touchy topic. Lots of opinion on it, stock is the safest and best option to go. From what I found the dry rechargeables like amsoil lose their breathing capabilities after a while but still filter. The opposite holds true for the K&N oiled filter.
I heard the Napa ones are pretty good too. Once again, all subjective.
I personally don't know of any, however you can pull mine and stick your finger in the mouth of the MAF and wipe an oily black grit out of there. It can't be good for it.
#30
