Dynoing out the myth of Intake mods: The Results
Rating: Thread Rating: 3 votes, 5.00 average.
  #136
Old 07-15-2011, 02:38 PM
OCG35's Avatar
Originally Posted by sexyrob
yeah it's on my car for shows and such... I still put the stock one in when it matters. I did feel kinda weird about putting it back in knowing what I know, but my car is getting a little showy and it looks weird having the stock box in there.
you can dress up a shielded intake and have good results performance and looks... The configuration I run has worked very well for me - and in fact, better than OEM.... The OEM box can even be prettied up to be worthy of a clean bay, I did it (with a revup box) - until I realized it wasnt worth it and ditched it.
FWIW.
  #137
Old 07-15-2011, 02:40 PM
Jeff92se's Avatar
Red Card Crew
Stillen would be the best combo of both worlds (show and go)
  #138
Old 07-15-2011, 02:51 PM
sexyrob's Avatar
eh, just with all the wire tucking and smoothing I did in the engine bay, I wanted a more minimalist intake for showing... I was planning on building a heat shield for it but haven't got around to it yet.
  #139
Old 07-15-2011, 04:20 PM
OCG35's Avatar
damn it - dont agree with me Jeff ... you'll ruin the "special" relationship we've had all these years
  #140
Old 07-17-2011, 01:56 PM
Louisiana G35's Avatar
You really did a great job on this project man, it helped me a lot. But what people need to understand is that the only benefit to going with a K&N panel filter is the ability to clean and reuse it instead of throwing it away. All of the test done on the K&N vs a new oem panel filter produced less than 1 hp on the dyno. The latest was done by DSPORTS. The oem filter is good for 20,000 miles depending on where you live and drive. I don't put that many miles on my car a year so spending $12 bucks a year on an oem filter is not bad, plus im not sure about the filtration of the K&N because you can see through the filter. They rely on there oil to stop most of the dirt. Don't get me wrong im not saying it's not a good filter from the start, but after so many cleanings and reoilings just how good is the filter?
  #141
Old 07-19-2011, 06:12 PM
Dsskyline's Avatar
FWIW.
Mike can you post a pic of your intake and what you did?
  #142
Old 07-19-2011, 10:29 PM
OCG35's Avatar
Derek, I sold the revup box (had it painted same color as the base color of engine cover and snorkel in pics below)... never took pics of it - I only have pics of the current setup... there are more pics of engine bay in my garage (in profile)... I dont really have that many pics of the actual intake
  #143
Old 07-19-2011, 10:53 PM
Dsskyline's Avatar
Did you do anything to seal it from heat on the bottom? Nice engine bay the car has come a long way.
  #144
Old 07-20-2011, 08:36 PM
OCG35's Avatar
^^^ nah, there's not enough exposed to be a concern (for me anyway)...
Thanks for the comment - the car has been pretty much the same for almost 2 years now... the only thing recent was Racing Brake two piece rotors (they just came out with rears - finally)...
  #145
Old 12-21-2011, 11:39 AM
VQ35 revv's Avatar
So the last test is a new OEM filter. And it says it gains 8whp and 6wtq. I was just wondering how is that possible? That is matching the stillen box.... and its just the stock airbox?
  #146
Old 12-21-2011, 11:44 AM
sexyrob's Avatar
correct.
  #147
Old 12-21-2011, 05:49 PM
bsowhat1's Avatar
In the final runs the aftermarket intake plenum is still installed.
  #148
Old 01-13-2012, 07:27 PM
NJ6MT's Avatar
What the original poster did for the community with this comparison is a great thing but I have a couple problems with it. Why was the aftermarket plenum installed so early in the tests? I feel that this renders the intake comparisons after the plenum install useless. Also the g35 is so sensitive to heat soak. I don't care how you try to cool the car down between runs, if it is strapped to the dyno all day it is hot and heat soaked.
  #149
Old 01-28-2012, 11:48 AM
Drakaine's Avatar
So my take is that without a retune stock is best, I should go for my 5/16 spacer and exhaust first? Would a cone filter on stock do anything or I've always read good things about AEM inductions? I just want to know what to do before a re tune. Any ideas on which company has the best retune? Sorry just bought an 06 G35 coupe 6 mt and I'm trying to get the most from it.
  #150
Old 01-28-2012, 02:16 PM
Sylvan lake V35's Avatar
Who is best for retuning is subjective i would research your area and use a good local tuner that does uprev. I would do all of the bolt on mods prior to getting a tune other wise you will have to get it retuned.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Dynoing out the myth of Intake mods: The Results
