MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Engine, Drivetrain & Forced-Induction > Intake & Exhaust
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 11-01-2007, 03:41 AM
Quote:
Originally Posted by Bashar368
Does this really work
yup. its been passed down from generation to generation. Under extended load or racing conditions, it is possible to throw a code, but you can clear it at your local pep boys. Should read something along the lines of left bank...
  #32
Old 01-31-2009, 12:25 AM
do yu need to get an angled o2 sensor or a straight?
  #33
Old 02-03-2009, 01:21 PM
do straight o2 sensors work? or do you have to get angled ones?
  #34
Old 09-27-2009, 07:04 PM
elperuano's Avatar
Send a message via AIM to elperuano
gonna bring this thread back to life (hopefully) Is it ok to continue driving after the service engine soon light comes on after installing test pipes? 06 gmt here and service engine soon light came on day of installing test pipe.. gonna get it fixed soon just wanna make sure if its ok to drive wit it on ur should i keep it parked til i get the antifouler?
  #35
Old 10-10-2009, 01:17 AM
2004 Infiniti G35
it will be fine
  #36
Old 10-10-2009, 01:42 AM
2004 Infiniti G35
Send a message via AIM to dbroncos Send a message via MSN to dbroncos Send a message via Skype™ to dbroncos
does having a CEL light on due to o2 sensing unburnt fuel hurt ur engine performance at all or is it just to tell u that your exhaust is putting out too much bad fumes? if it doesn't hurt performance by screwin with the air/fuel ratio then it shouldn't matter, just ignore the light right?
__________________
2004 G35 Sedan 5AT - 6000k HIDs - Demon Eyes - 2 Kenwood 12s - 5/8" Spacer - Z-Tube
  #37
Old 10-29-2009, 12:29 AM
i see a couple of you are saying something about drilling out the fauler things. what needs to be drilled? i dont get it
__________________
ztube-KnN drop in-350z springs-18inch foose df5's
  #38
Old 11-04-2009, 03:33 PM
Hello. I recently changed out my Helix test pipes for my OEM cats again but the 02 sensor on the left cat was stripped, so now I'm driving with one missing 02 sensor. How would this affect my car in general and performance wise and is it ok to drive with a missing 02 sensor from the cat? Thanks in advance
  #39
Old 11-05-2009, 02:50 PM
What are the pros and cons of the test pipes? in your guys opinion is it worth it ? just wondering ( im about to MAYBE get a set)
  #40
Old 11-05-2009, 03:20 PM
Pros:
- Performance WAY better than stock cats
- Performance a tad better than HFC's
- One of the only bang for your buck mods for a g35
- Increased sound levels
Cons:
- Gas smell when stopped and windows down
- Possible CEL
- Possible rasp ( Eliminated to minimum with resonated test pipes )
In my opinion the mod is def worth it.
  #41
Old 11-06-2009, 03:00 PM
thanks hamerykon....
for anyone that has these .....
Did the sound of the exhaust change your response to...
"man that sounds F@#$'n Awesome!"
"..that sounds like Crap man..."
  #42
Old 11-06-2009, 03:27 PM
YourKuh, there's definitely some rasp with the test pipes. When I first installed my Helix test pipes it was pretty raspy but not exactly annoying. However, with time (I'd say a few thousand miles) the rasp died down. I even grew to like it. With the stock exhaust, at cold startup the sound is deeper. At around 2500-4000 rpm the exhaust note is a tad bit louder but dies down at higher rpms with moderate acceleration. At WOT on the other hand is slightly louder, not necessarily deeper, than stock. I'm not sure if this is the same as other test pipes however. Overall, I liked the addition of the test pipes, but I did notice the car consumed more gas over stock.
Tags
2004, coupe, defouler, fouler, g35, nonfouler, plug, spark
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
