Rev-up Airbox or JWT Popcharger?
+1. The day I floored my car in only 85 degree weather and felt NO acceleration.. Was the day I put my Revup air box back on. Never putting another aftermarket intake on my car.
djhiro, in the real world there are no gains from any intake only a sound change. Manufactures will make all kinds of claims but with our G35s they're not true. The Rev-up air box/K&N drop in filter is your best choice, Popchargers lose major HP due to their aluminum pipe design causing heat soak. (heated incoming air)
Gary
Gary
Also, me and my friend have identical G's and without the pop charger it was a pretty even race. With the pop charger I pull his car at the end of every gear. We both can tell that approaching 6k rpms the power difference is noticeable and pulls harder. Lets say that the power difference isnt much, the sound wins for me.
Ill take the better sounding intake (pop charger) every day of the week. I drove in 108 degree weather yesterday and 100+ today for a total of about 7 hours and at no point did I feel my car lose significant power to heat soak. Either way, who races or floors it in extreme hot conditions?
JaE35 (06-18-2012)
Actually I lied, I took it off because I couldn't hear it over my Motordyne TDX2 w/ ART pipes. I prefer parts that actually make power. If youre driving in 108 degrees and cant feel it, then i don't think you can identify heat soak. Look at the countless threads about it, and the universal knowledge regarding the pop charger and high IAT. I think you're biased because of your new found intake noise. Just be patient, you'll feel the heat soak eventually
Well I do feel the heat soak, just not significantly enough like i said. And again, im not looking for power in hot weather, ill take the sound. The best advice I can give about intakes for our cars is this: If you are buying it for performance youre doing it wrong. The pros and cons are so minimal its absolutely absurd how people can bash it in either direction.
Gary
Gary
I'm confused... I'm new here so play nice.
Is this what y'all are talking about?
If so....
Is this any better for performance gains?
Am I missing somme thing here? Haha
If so....
Yes and No
The Ztube is just the stock intake air piping that goes from the MAF to the intake plenum from the original 350Z
I have have had all of them, I have the NISMO R tune CAI now, I could tell no difference between them other than the extra noise from the NISMO.and the Ztube.
BTW, I bought my R tune for less than $150 used.
Yes and No
Do you think the R-Tune is over rated?
you are only getting minimal gains(2-4 hp i heard) with the z-tube and a oem stock air box(better to run with a rev-up air box or z-box) Even with the heat shield, you will lose alot of power.Only way to tell is to tune it.
Basically if you want sound run the JWT Charger. If you want gains n a lil sound run the z-tube with rev-up air box or z-box. Only real gains will occur if you perform a tune.
But the gains don't really matter - how are a few extra horses going to matter when it comes to accelerating when it's torque that takes care of that?
#30
Been there, done that, and I'm sure I'm not the only one. You gain a bit up top, but you lose a lot of usable power in the heat.
