Exhaust leak
I drove ttrank's car solo
Received 1,486 Likes
on
It's probably a flange, flex pipe, or something like that. You can put some SeaFoam in your crankcase and look to see where the smoke leaks from. I'd recommend doing this outside though, I did this to find out my flex pipes were bad. I put a new Y-pipe on and then had Meineke remove the flange from my mid-pipe to muffler and weld a sleeve in place, since that was leaking as well. I don't plan on doing anything with my exhaust so this was an acceptable solution.
I think it cost me about 400 bucks total, buying the y-pipe, installing it myself, and then having Meineke weld the sleeve on.
g35xkamar
V36 Brakes, Suspension, Wheels & Tires
09-24-2016 10:10 AM
Kiva.hi
09-23-2016 03:50 AM
