Clogged PCV hose?
Clogged PCV hose?
I'm wondering if the OEM PCV hose (passenger side) is supposed to restrict the amount of air it passes through or if mine was clogged? When i changed out my hoses with Z1 silicone hoses I noticed the OEM was very restricted and the Z1 was wide open.
What's interesting is that i felt an improvement in throttle response after swapping out my vacuum hoses. I did a few other things, so I can't pinpoint what exactly helped with my car bogging down low. If the OEM hose is indeed supposed to be unrestricted, I was being robbed of power from this clog.
I suggest you take a look at the hose coming off the plenum into the battery area (goes to brake booster). This could help someone tracking down a hesitation in the lower RPMS.
Originally Posted by coffeysm
That's not your PCV hose it's part of the braking system it's a check valve that makes it easier for you to brake. It even states on the Z1 site to put the check valve into the new hose prior to installation.
