Another window problem
On Sunday the passage side widow motor went out with the window full down position. Well I replaced it last night with a remained one and it worked perfectly, I down the whole window reset deal because it would roll fully up when I used the auto up feature. Well that fixed it till I got off work today and rolled it down.
So I rolled it down, it began to rain, rolled the windows up with the auto feature. Passage side goes half way up and stopped, then I used the manual up.
I get home and open the passager side door. Window does its normal down a 1/4in, ok so I shut the door in hope it would go up. Well it didn't , so I proceed to roll it up manually, no luck. Hit the down switch, went half way and stopped. So i pull on the glass a bit then try to roll it up, it moved a bit then I hit the down switch and the SOB went full down and it stuck again.
Need some guidance please help
two window motors later and the part store screwing up my order, ive got one that works.
Dont buy remaned parts
