Notices
Sponsored By:
Sponsored By:
Window motor missing reset switch?
Old 11-21-2015, 06:07 PM
G35 Chief's Avatar
Hey guys my window is doing the classic 'up to the top and then back down 1/4 of the way' due to the anti pinch feature. Obviously it needs to be reset so when I took the panel off to reveal the motor, there is no reset switch to be found. The motor is apparently not the original as the guy I bought it off of said he had it replaced. Attached below is a few pics of what I'm talking about. Any advice on what to do from here would be much appreciated. I've just never seen a window motor lacking a reset switch before whether it's an original from infiniti or otherwise...
Car is a 2004 G35 coupe 6mt.
Thanks!
Attached Thumbnails Window motor missing reset switch?-window-motor-1.jpg   Window motor missing reset switch?-window-motor-2.jpg   Window motor missing reset switch?-window-motor-3.jpg
Old 11-21-2015, 08:28 PM
hurleyguys's Avatar
can you take a pic of the otherside. i think the reset button is on the other side. it is on the side that bolts to the metal plate. when i had to reset my window motor. i took the plastic door panel off then there was a little black sticker that covered the reset button,
Old 11-21-2015, 08:36 PM
G35 Chief's Avatar
yeah absolutely thanks for the reply. I've looked over this thing top to bottom but maybe you'll see something I missed
Attached Thumbnails Window motor missing reset switch?-window-motor-4.jpg   Window motor missing reset switch?-window-motor-5.jpg
Old 11-21-2015, 09:55 PM
andrewvk's Avatar
my reset switch was moving. so it may be removable.
i havent yanked my panel to see though.
G35 Chief (11-28-2015)
Old 11-21-2015, 10:07 PM
G35 Chief's Avatar
that may make some sense since I can see the plastic gears moving through the hole where the switch should be. I'm going to try to stick something in the hole against the gears to see if the reset switch it friction based and maybe it'll work. I'll let you know.
Old 11-21-2015, 10:23 PM
G35 Chief's Avatar
Alright so here's what I just did. I noticed a pin on one of the gears inside the reset switch hole. I took a needle nose pliers and grabbed the pin as I performed the window reset procedure and it actually kinda worked. The window started dropping again a little while opening the door and going back up slightly when closing the door. It's not dropping as much as the passenger door so could that just be a lubrication issue? thanks for the help.
Old 11-23-2015, 07:38 PM
saywat?'s Avatar
one thing i learned is with aftermarket motors its not gonna drop the same length. so long it drops like it should thats all that matters. maybe oem motors are more consistent with the drop amount idk. as for the missing button its jus a rubber gromment thing that stops the white part from turning when the button is pushed against it. so jus reenact the button being pushed by using a pen or eraser head. or anything jus to prevent it from turning and should be good.
Old 11-28-2015, 07:38 PM
G35 Chief's Avatar
^ wow you pretty much answered all my questions right there. Thanks for the help guys it works now so it's all good. Appreciate it.
Old 11-29-2015, 10:55 PM
saywat?'s Avatar
no prob
mattdg35
09-14-2015 11:28 AM
G35-2004-mt6
09-11-2015 04:16 PM
VANST3R
Lights
09-09-2015 02:32 AM
Jnm07
09-05-2015 01:16 AM
Quick Reply: Window motor missing reset switch?
