What part is this
You can probably find one significantly cheaper at a junk yard or...
http://www.ebay.com/sch/i.html?_odkw...pport&_sacat=0
dukehotty (03-24-2016)
A small piece of glass filled nylon sheet could be epoxied in, shaped with files or sandpaper, and drilled for a pretty clean repair that would be fairly quick and cheap.
JB Weld or another high strength epoxy should work well and a small piece of the material can be purchased here:
www.mcmaster.com/#1473t11
Along those same lines, the radiator support is more than likely a glass filled nylon given the "glass fiber composite" markings on it.
paky786
09-07-2016 10:20 PM
Gdup35sedan
04-07-2016 03:24 PM
