Telescopic steering wheel column
Just updating this thread to say that I bought a manual telescopic steering column from an 05+ coupe and it is possible to swap the column, but there are some complications that need to be resolved and I am in the process of doing that. I can put together a DIY for those interested.
Is there anyone that could use a write-up on this?
Ka$h (05-30-2023)
Also, did you ever write a DIY? I would love to read it if you did!
thanks in advance!
Kash
hi @Row2k , I am interested in telescoping functionality for my 04 G coupe steering wheel. Can you explain the complications you had? How is it holding up after 6 years?
thanks in advance!
Kash
thanks in advance!
Kash
That said I wouldn't do this again as there is a better alternative if you have the same problem as me. What you want is this:
https://www.spacershop.com/en/produc...r-nissan-350z/
The install is 10x easier and brings the steering wheel closer to your chest so your feet and legs are in a much better position for heel-toe at the track
SPiDi
08-27-2011 12:59 PM
