Replace chrome window molding? 05 Sedan
I just bought a new-to-me (used) 2005 G35 sedan. The only thing wrong with it is that the chrome molding below the from passenger window is dented. I'm planning on taking it to the dealership in a couple weeks to get some maintenance but wanted to see if anyone know how much a replacement chrome piece costs and if it's possible to DIY?
Thanks.
Thanks.
Originally Posted by NomadicRiley
Where did you get the part? I'm not even sure what those pieces are called.
The only reason I know all this is because I spent about 6 weeks dealing with all sorts of issues regarding window trim/molding because I had mine removed, painted and reinstalled...
Good luck.
Originally Posted by mjk
How did you go about removing the chrome trim "belt molding" around the window area?
thanks
thanks
Anyway, I had a body shop remove all mine to paint. How they did it? I don't know, sorry. I will say this - If you plan on re-using it (as I did) be VERY careful! It bends easily... It's very thin aluminum - not ultra delicate but if you're not careful you won’t be able to re-install. That's why I had a body shop do it.
will091195
07-27-2015 09:19 PM
