MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > Body Interior Exterior Lighting > Interior
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 04-30-2008, 12:17 AM
Lights on P R N D on the shifter?
so I have a 2003 Sedan and I can't remember if the "P R N D" used to light up on the shifter plate? If so, it's out now...what's the replacement bulb and can I get under it with just removing the plate or do I have to remove the whole center panel?
Thanks, i just know the dealer will stick it to me!
Old 04-30-2008, 09:13 AM
Support your local G
Yes the shifter plate is supposed to light up. I'm not sure on the process of replacing the light (or even whether it's a bulb or LED soldered to a circuit board). You can try to do a search for "shifter light" and see what results you get.
__________________
03.5 5AT BS 4DR | remote start | JDM clears | JDM RH batt. cover | Z-tube | SB LEDs | Hawk HPS pads | Stillen sways | 06 tails | lip spoiler | flat black grille | Eibach Pro-Kit | 19" HP Evo's | Stillen GR kit | Luminics yellow fogs | MOMO shifter | MD 5/16" iso spacer | 06 midpipe | NRG hood shocks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
