Notices
G37 Steering wheel on a G35?
Old 09-01-2015, 07:14 PM
.cakestar's Avatar
lol so im doing this conversion right now and realized how the previous people were able to do it, they dont use the steering wheel controls for the radio bec they have aftermarket radios. im mapping this out and everything is in the wrong places. hahah its going to take a lot of remapping and soldering to get this damn thing to work correctly
LoSt180 (09-03-2015)
  #77
Old 09-10-2015, 03:58 AM
.cakestar's Avatar
here is what is needed to make the g37 steering wheel buttons work with stock radio and bluetooth. for the top button make sure you sever the connection above the point where the white wire connects to from behind. red is where you need to cut. the g37 steering wheel buttons have an extra button, telephone hangup and mode are one button on the g35 and its separated on the g37 one so i wired both buttons to have the same function
The following 2 users liked this post by .cakestar:
2 Gs (08-18-2019), TokkioDrift (12-21-2020)
  #78
Old 04-06-2016, 10:49 PM
Pumacelled's Avatar
I know this is an old thread, I just ordered a g37 steering wheel with the airbag, anyone who's done this can you confirm if the pigtail harness (yellow & orange connectors) from the g35 clock spring plug right into the g37 airbag with no problem? I also need to know what i need to do to make sure cruise control and audio controls work as well as the button lighting on the steering wheel. Also Cakestar you've got pm dude.
  #79
Old 05-08-2016, 02:40 PM
Pumacelled's Avatar
Thought i'd update this thread, i'm sure many won't care but this is a mod i really wanted, and it is definately more than worth it. i lucked up and found an ipl g37 steering wheel with the red stitching on eBay for like 160 bucks (I've never clicked a button so fast to purchase something in my life, the wheel alone is 1100 without the airbag), ordered a g37 airbag a few days later, finally found time to install everything yesterday. I unpinned the harness and matched it to the 06 g35 harness and all buttons work with no issues. There's another thread on here somewhere that i used for repining the harness as well. The install took 30 min max. Hands down this is the best mod i've done so far.
Attached Thumbnails G37 Steering wheel on a G35?-img_2007.jpg   G37 Steering wheel on a G35?-img_2005.jpg   G37 Steering wheel on a G35?-img_2021.jpg
NjMatteSedan (11-04-2016)
  #80
Old 05-08-2016, 06:06 PM
.cakestar's Avatar
oh nice! the buttons for the radio didnt need to be modified? maybe it is because you have an 04. on my 06 the radio buttons were all off
  #81
Old 05-08-2016, 06:38 PM
Pumacelled's Avatar
nope, didn't have to modify anything except for repinning the harness. Gotta say that wheel makes the car feel brand new it's kinda ridiculous lol. Also thanks for the help cakestar.
  #82
Old 05-08-2016, 07:48 PM
.cakestar's Avatar
thats crazy. all of the radio buttons function correctly? like every button does what it should? vol up down mode and everything? when i pinned it up before my mode button was like vol down and so on
edit: actually are you 100% sure all the buttons are functioning as they should? i know the 06 steering wheel light up buttons swap to 04 doesnt require any modifications. so technically it should be using the same resistance for each button..
  #83
Old 05-09-2016, 12:32 PM
Pumacelled's Avatar
Yea 210% sure, all buttons work as they should without issue, I know when I first repinned the harness i had mixed buttons so I unhooked the battery so I could Unpin/repin the harness. No issues, I have an 03 if that matters, it shouldn't though. You using the factory radio?
  #84
Old 05-09-2016, 04:24 PM
.cakestar's Avatar
yep. using factory radio on my 06. none of the buttons worked correctly in the beginning
  #85
Old 05-09-2016, 08:45 PM
Frostbite91's Avatar
huh, I may have to find a G37 steering wheel now lol. Did you by chance make a diagram of the harness when you re-pinned it?
  #86
Old 05-10-2016, 01:21 AM
.cakestar's Avatar
what does your repinned harness look like? this is my stock 06 harness
  #87
Old 05-10-2016, 09:24 AM
Pumacelled's Avatar
That's identical to how I pinned mine the first time, however my buttons were a little mixed up (volume down turned off radio, back button turned volume down) I honestly can't remember pin for pin how I adjusted mine. Also my factory wheel and g37 wheel harness' are a little different, my g37 wheel has 2 yellow wires and a pink wire, my factory wheel had neither of these wires. When I get time I'll see if I can unbutton everything and grab a pic, it's been rainy lately so may be a bit though.
Also the only buttons that don't work are the phone, and talk buttons.
Source=mode|up & down=seek|+ & -=volume/back button=power.
  #88
Old 05-10-2016, 09:29 AM
Pumacelled's Avatar
I didn't unfortunately.
  #89
Old 05-15-2017, 11:41 AM
cturnbull802's Avatar
does anyone have a picture of the correct pinout for functioning radio buttons yet? i ordered a flat bottom carbon g37 wheel and am excited to get it installed once it shows up
  #90
Old 06-24-2018, 02:17 PM
flechapr's Avatar
Any picture of the pinout?
Quick Reply: G37 Steering wheel on a G35?
