Notices
HELP!!!!! Mounting r35 GTR seats in the G35 coupe
Old 12-05-2012, 02:26 PM
guitarrocker98's Avatar
As some of you know I'm gutting my interior and doing a complete overhaul on it. I started a new thread, because this is a different subject than my tear down and build up. I have been working on dual ring tails, and I'm switching my interior cluster to the 06 cluster, and swapping my interior lighting to white and blue. Anyways I picked up a set of Recaro GTR seats that the airbags were deployed in. My goal was to keep heated seats and airbags, but to have a more snug racing style seat. Hence why I jumped at the GTR seats.
I will get pics of what I'm talking about later
My goal was to swap the rails, and I was hoping that was all I needed to do, and I would keep the power seats. Well the problem is that there is a long screw piece that goes I between the rails so that the motor will move the seat forward and back. Well when I swapped the rails, that screw is not long enough to go I between the two. Also the angle is way,off on the seats. I will post pics soon of what I'm talking about. I thought all was lost, and I was going to bag the project, but I thought if got brackets and sliders this may still work. The GTR seats have a power back though where ours is the pull bar that causes the back rest to go forward and back. I feared that the motor that controlled the seat controlled that somehow. Also, the driver seat has a power raise and lower on the butt ant thighs. Good news Is I found out both are run by different motors. What I need to check is if I have clearance for the slider and bracket on the drivers side.
WHAT I NEED HELP WITH AND IDEAS
Since the seats were original to Recaro, should I get Recaro sliders on it? Should I go with Wedge or Planted for the seat bracket. I need ideas and help on this. Anything will be great.
Old 02-11-2013, 08:57 PM
Okay, I am having some issues Namely with the wiring. So... I need some help. I know some people have swapped sedan-coupe seats and know what wires do what in the car. I will snap a pic of the wiring in the GTR seat and the Wiring I need to hard wire into the GTR seat. Please help me. One thing I noticed right off the bat was that the GTR sears harness was much much smaller, and there were fewer wires to go into. I tried to wire some things in and see if I could figure out what did what, but my issue is that I dont think there is any power going to the switch that the GTR seat uses. So Even though I have power going to the wire, there is nothing to tell it to go on and off, therefore it does nothing. So any help would be great, even if its just explaining what the wires on my 04 Coupe harness does. If someone could find the Wiring for the GTR seat that would be AMAZING!!!
Old 02-11-2013, 09:10 PM
JaE35's Avatar
Moderator
G35 Sedan
Good luck, how do the brackets line up outside of the wiring with the stock mounting points?
Old 02-11-2013, 09:29 PM
They dont at all. I have another thread on here that has my tear down and build up. What I did was hope (knowing the brackets would not work) that they would haha, when they didnt I hoped I could take the brackets of my coupe seats and toss them on my GTR seats, so they would line up and I could keep all functions of the seats... Well that didnt work because they are different widths, so I have Recaro Rails and im fighting between wedge preformance and another brands bases.
Old 02-11-2013, 09:30 PM
Okay here are the pics I need some help with.
This is the Harness from the G35 coupe
Here is the GTR harness.
I will no longer have a forward to backward in my car with a motor, but If I can get some help on how to wire it up. Anyone with anykind of experience on this would greatly help. I was trying to hard wire straight to the motors themselves but like I stated I think all the power was going to them, and the switch was not turning it on and off, but rather left it open and on which really didnt cause it to move or anything at all...
Old 02-11-2013, 09:39 PM
Frankieg35's Avatar
Can u just swap over the whole harness and motors from the oem seat to the gtr seats??
Old 02-11-2013, 09:46 PM
Its doubtful. My guess is they are different. I can take a look into it though. I believe the motors are different. My guess is I will probably have to cut off the harnesses and rewire it move the OEM one to the GTR seat so it will all plug in. I will try and see if the motors would just swap that would be ideal... but I have my doubts. ESP because the buttons are different.
Old 02-11-2013, 09:55 PM
Frankieg35's Avatar
Hmm, id have to see it.. I wish I was local id luv to give u a hand to get this to work.. lol
Old 02-11-2013, 10:00 PM
Well I posted to a GTR forum... Hope they dont eat me alive..... The wires that I have to go down to on this connector is on the top
fat black
white
white with red
fat red
bottom
blue with white
thin black
I am now finding out that there is another connector for the heated seats that is entirely seperate from this, so thats good to know.
Old 02-11-2013, 10:11 PM
JaE35's Avatar
Moderator
G35 Sedan
I have a local that has done quite a few installs of coupe seats in the sedan and should know the wiring very well...i'd give him a holler r1 autoworks on here
Old 02-11-2013, 10:22 PM
I appreciate it
Old 02-11-2013, 10:53 PM
I just messaged him, so well see he last got on in January...
Old 02-12-2013, 01:53 AM
Frankieg35's Avatar
He is on all the time, actually latest was today..
Old 02-12-2013, 02:13 AM
Haha yea!!!! He has posts today, but when I look at when he last got on it says 1-27-13..... Idk
Old 02-12-2013, 03:40 PM
Well I've decided since I'm never really going back to stock seats what I'm going to do is cut the harness off, and try and wire them up manually. If I can kinda figure out what does what. Really I first Need to find the 12v power and grounds which I believe will be the thicker wires. If these seats don't work out, ill be doing a custom set of either cipher auto recaro or sparco's just gotta figure out which ones if the gtr seats don't work I will do. So once again if anyone has any wiring advice on these I would love it.
Quick Reply: HELP!!!!! Mounting r35 GTR seats in the G35 coupe
