Notices
Sunroof problem
Old 07-19-2014, 03:57 PM
Frankieg35's Avatar
Sunroof problem
I tried to close my sunroof and it was making a horrible noise so I looked in the track and there is a bunch of broken plastic, one piece had a metal clip in it.. Sunroof still opens and closes..
Old 07-19-2014, 04:23 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Maybe a robot dinosaur got caught in the track and got eaten up
I'll look into it when I get to my computer.
Frankieg35 (07-19-2014)
Old 07-19-2014, 05:04 PM
Frankieg35's Avatar
I pushed up on it when it's closed and it still feels tight..
Old 07-19-2014, 07:02 PM
JKL1031's Avatar
Are you an engineer for Niss/Fini?
Old 07-19-2014, 07:16 PM
Good Joke.
Like Lost, I am just crafty and will look into a solution because it is a problem that will affect me eventually.
Old 07-19-2014, 07:20 PM
JKL1031's Avatar
Oh. You threw me off when you said look at it on the computer
Old 07-19-2014, 09:01 PM
Frankieg35's Avatar
I'm afraid to open it in case it doesn't close..
Old 07-19-2014, 10:27 PM
dukehotty's Avatar
Hey Frankie, my sunroof was making a noise then it just stopped working with the glass tilted open. It ended up being the two screws that hold the motor in place. One fell out and the other was half way loose.
I followed this link, it is VERY easy, and it fixed my problem. I hope you have the same problem. Good luck!
https://g35driver.com/forums/v36-diy...all-v36-s.html
Old 07-19-2014, 10:54 PM
Frankieg35's Avatar
I don't think that's my problem because I had broken black plastic in my track and one piece had a piece of metal, like some sort of clip in it..
Old 07-19-2014, 11:16 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
You have broken parts, have them replaced!
If you use your sunroof as much as I do you should have Nissan replace whatever parts are broken. I suggest once it's fixed, every few months clean the railing and put a dab of Silicone lubricant on the rails. It doesn't dry out or gum up like WD40 and it should always run smooth...Gary
Old 07-20-2014, 12:44 AM
Frankieg35's Avatar
It's open all the time if it's not raining.. Lol I need to get it looked at, Nissan can do it or should I go to infiniti?? Do I have to drop my headliner??
Old 07-21-2014, 11:41 PM
Frankie. Here are a few pictures from the Roof (RF.pdf in the FSM) section that may point to the plastic thing we found ground up.
Attachment #1 is a birds eye view of the Sunroof Rooftop area. The numbers are explained by the legend in attachment #2.
I think what ground up in your track is in attachment #3. These are called sunshade stoppers. A few too many bicep curls at the gym probably caused you to break one of these over the 8 years of ownership.
Attachments #4 and #5 are other parts in that area that could have also been possibly damaged, but I am really leaning towards the sunshade stoppers (the plastic part you slide).
Hope this solves your issue.
PS... http://www.orderinfinitiparts.com/pa...hade%20stopper
Attached Thumbnails Sunroof problem-screen-shot-2014-07-21-11.22.58-pm.png   Sunroof problem-screen-shot-2014-07-21-11.23.21-pm.png   Sunroof problem-screen-shot-2014-07-21-11.23.50-pm.png   Sunroof problem-screen-shot-2014-07-21-11.24.07-pm.png   Sunroof problem-screen-shot-2014-07-21-11.24.15-pm.png
Old 07-21-2014, 11:46 PM
Frankieg35's Avatar
It was under the track if you are looking from the top on the passenger side in about the middle.. I wanted to take a pic of it but I was so pissed I threw it on the ground.. Lol
Old 07-21-2014, 11:51 PM
So I did help?
I was missing one... Maybe the previous owner had a fit of rage also.
Plus, test your seatbelt arrest ability... I discovered today while driving mine doesn't activate at all and Infiniti will replace all of my belts FOR FREE and will give me a loaner while I wait.
Old 07-22-2014, 12:08 AM
Frankieg35's Avatar
I dunno I will look at it tomorrow, I'm afraid to open it in case it doesn't close.. Lol
Quick Reply: Sunroof problem
