How do I remove passenger side carpet?
Passenger side?
It's all one piece for the entire car, but if you're looking to just lift up a bit, pull the rubber door seal, remove the plastic footwell cover, pry the kickpanels up from the door sill, then lift the black plastic rings from around the plastic tabs. If you need to get more of the carpet out, you'll have to take the seats out and much more of the interior trim.
An in-progress picture:
Here you can see a low-angle picture that shows the white plastic tabs that hold the door sill plates in place and which are encircled by the plastic carpet anchors.
Micale757
Lighting
04-08-2020 10:46 AM
