Notices
Painting Seat Belt Plastics?
Old 03-01-2015, 05:28 PM
DigitalDeviant's Avatar
Does anyone have a guide on painting the seat belt plasics? The rear pillar bezel can't come off the belt, so I assume people are just spraying it in the car? As far as the front seat belts go, any help would be appreciated.
Old 03-01-2015, 11:38 PM
bigc's Avatar
Wings Nation
Spraying it in the car would suck. Just unbolt the seat belt and tensioner, remove it from the car with that little plastic guide hole thing (i believe this is the bezel you're referring to) attached, then paint it. Same idea for the front.
FYI, if you do this, your seat belt may retract into the tensioner and seem to get stuck. It isn't really, the tensioner just needs to be at the proper angle to allow the belt to be pulled out. When you bolt the tensioner back in the car it'll work fine. If you don't want to worry about this, however, just wrap some tape around the tensioner so that the belt won't retract. Remove the tape after you reinstall everything.
Painting it by hand is another option if you don't want to have to deal with all of this. Its a small piece so you won't notice the brush strokes anyway.
Old 03-01-2015, 11:41 PM
.cakestar's Avatar
my idea was to actually dremel a thin slit in it and just take it off of the seat belt. cutting it in a spot where it would be hidden when the seatbelt is retracted, could look stock if you do it right
bigc (03-02-2015)
Old 03-02-2015, 02:55 AM
guitarrocker98's Avatar
You could use dye instead of paint... Not sure if that would work at all though... I'm painting and wrapping mine but im getting blue seat belts installed...
jilljann1
07-21-2020 08:12 AM
cmesidewayz
09-29-2015 09:28 PM
zcherub
09-10-2015 12:03 PM
pasjr1972
09-01-2015 10:17 PM
Quick Reply: Painting Seat Belt Plastics?
