Notices
taking the headlight apart???
Old 03-19-2007, 07:03 PM
Teamsr2k1's Avatar
Does anyone know how to take the headlight housing apart to remove the amber lens on the turn signal to make it clear?
Old 03-19-2007, 07:05 PM
redlude97's Avatar
It requires baking it, try a search
Old 03-20-2007, 07:51 AM
Espresso's Avatar
Preheat oven set for 200°F. Bake for 10-12 mins. Pull apart plastic housing. Dremel out amber lens. Replace with clear lens. Re-bake until glue softens and press together.
Old 03-20-2007, 12:04 PM
Calvin's Avatar
Overglorified Altima
Old 03-20-2007, 02:15 PM
ILLicit's Avatar
You cant just remove the amber piece, it nees to be cut out. It's a real PITA.
Old 03-20-2007, 02:28 PM
ttrank's Avatar
Grocery getter
^^ +1
I have had mine open ~6 times.
Old 03-20-2007, 03:17 PM
redlude97's Avatar
Originally Posted by ttrank
^^ +1
Did you have to add any sealant after opening that many times? I've only opened headlights once and never needed to open again, but I will need to reopen mine soon to install the clear lense projectors
Old 03-22-2007, 06:32 AM
Teamsr2k1's Avatar
also how hard is it to put the projectors in a sedan? Any special clear lenses that you all have used to replace the amber ones?
Old 03-22-2007, 11:53 AM
Espresso's Avatar
I'd do a search. Lots of info on clearing out your ambers and some sedan members doing a projector retrofit. Like this one.
Old 04-03-2007, 06:28 AM
Teamsr2k1's Avatar
im thinkin I dont know if I want to challenge taking the light apart and making the signal clear. Kinda sounds like a pain to me
bu villain
Accessories
63
08-25-2016 07:14 PM
Cam_Cooper3
08-04-2015 01:53 PM
neight
08-02-2015 03:01 PM
Quick Reply: taking the headlight apart???
