Daytime Running Lights Help Needed
on
So I bought a car in the states and I need to install the Daytime Running Lights to comply with Canadian laws. I initially planned on just wiring a simple relay to a 12V ignition source to trigger the fog lights. I don't mind them being on at full power. Is this going to be as easy as it seems or am I going to have problems with the IPDM and BCD? I found a diagram of the exact way I want to wire it on the12volt.com. Where it says DRL is where I will connect the fog lights. Please let me know if this will work before I start throwing up error codes.
Hasanbaloch
02-29-2024 08:45 PM
Wayne9011
07-27-2015 11:25 AM
