Thread Tools | Search this Thread | Rate Thread | Display Modes |
Finding a 12v source with ignition on for DRL
I have installed my DRL module and need a 12v source when the ignition is on in order to power the module. Does anyone have any idea where I could wire it to wether it is some component or fuse?
__________________
2004 G35 Coupe 6MT IP Last edited by bomberman447 : 07-24-2008 at 05:48 PM. Reason: new question about same module |
Alright I have it all wired up, I just need to connect the last wire to a 12v positive source that is on when the engine has started. The instructions from the module say to wrap it around the spark plug wire which I do not believe is really possible here, so does anyone have an idea where I can connect the wire to in order to have the module powered only when the car is started?
__________________
2004 G35 Coupe 6MT IP |
Try locating the power for the cigarette plug. For the engine bay area, I'm not exactly sure. I'm sure KPtechnologies would have better info for you.
__________________
![]() "Performance You Can See"® *IGT EXCLUSIVE* Carbon Fiber Headlights Lighting Modifications and Accessories/ Carbon Fiber Interior Kit |
Thanks for the info. I looked around but couldnt find it close enough for the wire so I ended off going for the oil pressure switch and it runs fine off of there, but the module does suck and all of my lights are on now, so I will likely have to go back in and make it so only the parking lights light up.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
