MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area > Body Interior Exterior Lighting > Lighting
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 08-14-2008, 11:10 AM
v-leds problem - how to test an H4/9003?
so I bought these H4 replacements for my fogs, although when I put them in, they don't light up...
anybody have any thoughts on why they're not working and how I can test them outside of my car? possibly with a multimeter?
Old 08-14-2008, 03:56 PM
you cannot test them with a multimeter, diodes are not linear electronic devices.
I am not sure what you need to test, if the old bulb works and the led does not get the led exchanged.
__________________
Vehicle: 2004 Black Obsidian Coupe||Tinted||19's from an 05||Clear Side Markers||Driver Mod
Old 08-14-2008, 10:58 PM
thx for tips calc, will probably try for a refund...
vled's response: "Use a 12v power source like the battery in your car, take two jumper wires and connect one end to the battery and the other end to the LED. Through this test you will find the plolarity layout of the LED bulb. You would need a test light to find out on your car. It is very possible the positive and negative just need to be swapped. Sometimes you can just pull the pins out of your harness connector and swap them around."
I'm less than eager to tap my car battery to this light / re-wire the harness, anybody try this before?
Old 08-15-2008, 06:32 AM
dranom's Avatar
WTF**
its doesnt light up on both sides?
__________________
Ivory Pearl 6MT coupe
--Team OCG--
Old 08-15-2008, 08:05 PM
yup, both sides are wired the same, neither side works with the LED bulbs
much respect to V-LEDS though, very responsive, agreed to refund (one was in fact defective)
thanks for the help guys!
Old 08-15-2008, 08:10 PM
BKZJAYY718's Avatar
<==You See iT
i would like to see a picture of this in action
Old 08-16-2008, 02:23 AM
as requested....
they're crazy bright
with proper exposure
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
