Thread Tools | Search this Thread | Rate Thread | Display Modes |
03 Corner Lights
I know this is a really n00b question, but how do I turn on the corner lights? It feels like I've tried everything and they do not turn on at all. Is it possible that the bulbs on both ends have died out?
They should come on with the parking lights... not sure if there is a separate fuse - are all the other lights working?
It’s doubtful that both bulbs went out at the same time... is the car used? If so maybe previous owner had clear corners and didn’t plug the OEMs all they in (if swapped before sell)... In any event, check the plugs to make sure they are all the way plugged in - the lenses pop right out and the plug is right there. |
Thanks for the reply. Yes, all the other lights work just fine. I will try to check the fuses to see if that helps. I was planning on getting new bulbs/clear corners anyway, so it's no sweat if they are blown. I just couldn't figure out how they turned on!
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
