Replace 3rd brake light - Cheap
My 3rd brake light recently went out. After doing some searching and removing the light, I realized replacing this LED assembly would be expensive (~200). I refuse to pay that much for a replacement light so I decided to come up with an alternative. In the end, I was able to integrate 4 red 12V bulbs into the existing LED housing. The new light is a little dimmer, but still very effective and enough to do the job. I have attached a few pictures. if anyone is interested in details, or wants me to modify their housing with new bulbs to save some money, let me know.
I had the same problem n refused to pay 250 for it. so i searched n found this site http://www.infinitipartsusa.com/part...layCatalogid=0 cost me around 130 which is hella alot cheaper consider i cant pass my safety inspection without it.
I have just tested my light assembly and only the middle 2 lights light up. How do I replace the other 4? Can I just rip them off and solder these on? http://www.ebay.com/itm/20pcs-PHILIP...item4ace302dd7
I was able to get this done and I am no electrics engineer. I am sure someone can write a better DIY but basically I just got my entire brake light out first. Unscrewed the LED strip from the assembly. I think it ws just 2 screws. I posted a link above from my previous post which were the bulbs I ordered. I believe Phillips lumileds. At the time I spent a lot of time researching what to get and got those linked above. There are different reds and stuff, and these seemed the closest fit. I replaced one bulb and used a 12 volt battery and it shorted a few out or something. So I literally pulled every bulb out with needle nosed pliers. I drilled tiny holes into the metal so I could sort of slip the feet of my new bulbs in and I soldered, was not pretty but I just made sure the feet were on the correct (polarity) side of metal. The ones that are stock are snapped in, but these replacements have to be soldered. I didnt even bother testing again with the battery. Just went outside and plugged into the car and it has been working ever since (6 months?) Hope this gets you going Toma. It is not hard, worst case you can just order an assembly off people on this forum for under $100. My total cost was literally like less than $10 tho.
Urbanengineer (07-29-2014)
Micale757
Lighting
04-08-2020 10:46 AM
Luisgalvan33
07-19-2018 08:16 PM
