| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
I got sucked into this idea one night and now since I bought the projectors, ballasts, and bulbs I have to finish it eventually
. I just need some help, i have searched but nothing is really helping. I don't understand the solenoid on the bottom? I came into this with no knowledge other then it looks like a good project. If someone could please explain the solenoid , what it does, how to hook it up? What I have in my hands right now is-extra headlight housing ( cheap ebay one ) -G35 Bi-Xenon HID OEM D2S -55watt ballasts with d2s bulbs. also I have 2 shrouds that fit like complete ****. So If anyone can point me to some good fitting ones please do ![]() my current struggle.... these are the ebay headlights... not even close to fitting in. any ideas? ![]() ![]() ![]() I will keep updating as I get further and get help from people. I will try to make a DIY once I figure it out myself for everyone ![]()
__________________
G35mods.com |coming soon. |
Is that housing for a sedan?
__________________
06 6MT AB coupe NAV/RAS, dual LED ring taillights http://g35driver.com/forums/g35-coup...aillights.html, super quad projector retrofit 55W S2000 + TL http://g35driver.com/forums/lighting...many-pics.html |
it controls the high beam function of the projectors
yes its a sedan 03. Also ok so now that makes a lot more sense. Thanks redlude.
__________________
So, you have a sedan then?
__________________
Check out my "OEM" Quad Projectors --> http://g35driver.com/forums/lighting...tor-hls-d.html
yes
__________________
you should mount the projector to the bracket that holds the reflectors so you can still have adjustability. Unless you need the bixenon function, i would opt to use a projector that is easier to mount and smaller such as the tsx
so should I just cut it out on the reflector? then stick it through and try to use its adjustability in some way. And yeah too late now ahaha I would of got those if I had known what I do now.
__________________
I actually am in the process of putting some fx 35 projectors in my sedan. I cut out the reflector but left the 2 screw mounting points that the adjuster connects too. I looked for some tsx and some s2000 but couldnt find any at a decent price
Quote:
__________________
well here is some more stuff.
![]() does this look right?
__________________
G35mods.com |coming soon. Last edited by Heist.; 09-24-2009 at 04:20 PM. |
Ok I need some help! I need mounting suggestions for the projector in the housing.
__________________
wow, i wanna do this so badly!
__________________
04 G35 Sedan RWD|Brilliant Silver/Graphite with Aero/Nismo Kit|Z-tube|JDM Battery cover|JDM Clear corners|NIsmo Oil cap|Coupe midpipe with HKS muffler|Stillen Sway bars |BC Racing Coils. |
broke both housing today........ GOing to make something totally custom to mount it stay tuned.
__________________
oh hella custom brackets ahaha. Using shelf hinges seemed to work out pretty decent now i just have to figure out a good way to aim them properly. These lights are night and day compared to OEM. Those were terrible.
![]() ![]() Once I finish i will post up more info and pictures.
__________________
| Tags |
| 2008, aim, aiming, build, coupe, d2s, dual, g35, g35modscom, hid, housing, infiniti, lighting, project, projector, projectors, retrofit, vertical |
| Thread Tools | |
| Display Modes | Rate This Thread |
