Headlight fuse location!!!! Help please
I replaced the headlight also and was hoping that would do it since I found out It was bad, but I was upset to find that it still doesn't turn on!!! Does anyone know what a car original come equipped as far as the headlights go? The headlights are after market so I'm thinking the grounding on the unit is bad if that's possible. Does this make sense anybody? I have an 06 sedan non x
Hey was riding down the road today and both my headlights went out. ????
The bright lights work. No low beam lights. When I tried to turn the switch off and back on again the lights tried to come on real faint and went off immediately. Brake lights and back park lights work. Any ideas what might be the problem? Bulbs, ballast?? Any information would be greatly appreciated. Thanks!
on
Check the BCM and IPDM as well as the harness connections
HEADLAMP HI/LO SWITCHING OPERATION• BCM transmits the high beam request signal to IPDM E/R and the combination meter (through unified meterand A/C amp.) with CAN communication according to the high beam switching condition. High beam switching condition- Lighting switch HI with the headlamp ON- Lighting switch PASS• Combination meter turns the high beam indicator lamp ON according to the high beam request signal. • IPDM E/R turns the integrated headlamp high relay ON, and turns the headlamp ON according to the highbeam request signal.
CHECK HEADLAMP (HI) OUTPUT VOLTAGECONSULT-III ACTIVE TEST1. Turn the ignition switch OFF.2. Disconnect the front combination lamp connector.3. Turn the ignition switch ON.4. Select "EXTERNAL LAMPS" of IPDM E/R active test item.5. With operating the test items, check the voltage between the IPDM E/R harness connector and the ground.JSLIA0003ZZHi: Headlamp switches to the high beam.Off: Headlamp OFFRevision: 2008 September
Fireman07603
08-09-2015 06:00 PM
