Notices
Custom Headlights question
Old 08-27-2013, 11:08 AM
ChrisKG35's Avatar
Cool Custom Headlights question
Hey guys wondering what it takes to get a clean headlight look specifically the side markers/clearance.. I've been searching but all I seem to come up with is the tacky LED strip. Don't like the look, way too ricey. Im looking for a headlight setup similar to this
Lmk thanks!
Old 08-27-2013, 11:31 AM
ChrisKG35's Avatar
Old 08-27-2013, 04:01 PM
the93owner's Avatar
The lights in your picture appear to be OEM 03-05 headlights with overlays or custom painted. The side markers look like they are aftermarket clear corners with LEDs... in my opinion the OEM JDM clear corners are the way to go.
Old 08-27-2013, 04:20 PM
Jaygotboost's Avatar
those are special led pods would cost (don't remember if ) $75 or $150 each side to do the clearance strip. two 5 led pods would go on each side, pm me if serious can get you those parts
Old 08-27-2013, 04:21 PM
WhosUrBuddiee's Avatar
They are not LEDs. It is called a CCFL that is retro fit into the headlight. Very cheap and simple modification. You can buy cheap 12" CCFL lights from svc.
http://www.svc.com/clk12.html
Basic steps
- Heat headlight in oven to open
- Remove clear plastic from clearance strip
- Take bandsaw or dremel and remove the excess plastic to allow CCFL to fit
- Mount CCFL in metal clearance strip with silicon
- Wire it all up
- Reassemble headlight.
It use to be a very popular mod years ago before the 06 projector lights become so popular.
The corners are dual LED strips. One white as normal and one amber as a turn. Similar to this one except he did two ambers as normal
Old 08-27-2013, 06:01 PM
UCIMAplaya2's Avatar
Anyone know of a good way to get the corner lights apart and back together? They seem to be plastic welded and I want to get them apart so I can put led strips or custom cut and assemble a circuit board to fill the housings evenly. I have a few ideas but someone with experience would be better.
Old 08-27-2013, 06:41 PM
Epoxy or plastic welder are the only ways. Epoxy is much easier.
You can also get everything necessary from a vendor here.
https://g35driver.com/forums/exterio...retrofits.html
Old 09-01-2013, 10:14 AM
ChrisKG35's Avatar
Totally forgot to check back into the thread lol, but Buddie found exactly what I wanted. Thanks guys!
Old 09-01-2013, 10:17 AM
ChrisKG35's Avatar
Basic steps
- Wire it all up
Any pictures of the CCFL in the off state and in the daytime? I want to see how you would see the long bar. Also can you elaborate on the corner LED strips
Old 09-01-2013, 12:11 PM
Off state in daytime, the look exactly like normal 03-04 headlights. The ccfl is not visable under the clearance strip.
There are DIYs on here I'm sure. You basically cut the seam with a dremel, silicon in some led strips, use epoxy to reseal the light, wire it up.
Here is a set of ccfl clearance strips I did on my first G35 during the day.
Old 09-01-2013, 02:05 PM
ChrisKG35's Avatar
Looks perfect!! All the DIY have expired images, I don't want to do this project half blind anyway you can do a write up? Thanks!
Old 09-01-2013, 06:20 PM
kmoore22's Avatar
What did you use to "clear" the turn signal in the light housing?
Old 09-02-2013, 07:54 AM
You dont need pics, just follow the steps, it is very simple.
Old 09-02-2013, 07:56 AM
The amber is part of the housing, you need to use a dremel and cut it out. You can buy clear plastic sheets at Home Depot or just leave it open.
Old 10-21-2013, 04:54 PM
PERKS11's Avatar
post for future use...please ignore the month old bump...
bu villain
Accessories
63
08-25-2016 07:14 PM
linedr89
08-17-2015 05:11 PM
noctilucous
2nd Gen (V36) Sedan
08-06-2015 08:47 PM
G35Sask
Intake & Exhaust
16
08-05-2015 10:17 PM
Quick Reply: Custom Headlights question
