2004 G35x sedan left LED brake light out
Hello! I'm a new member and new G35 driver. I've had my 2004 G35x sedan for the past year and I'm loving it. I'm having trouble finding an answer to my problem in my forum searches.
My LED brake light has gone out on the left tail light, all of the LEDs. The other lights in the assembly are working fine. All the lights on the passenger side are also working fine.
Is it likely that all the LEDs have stopped working and I need to replace the assembly or are those LEDs on a separate fuse? I checked the fuse box inside the car and everything seemed fine but I wasn't sure if these lights were on anything in the boxes under the hood or I overlooked something.
I wasn't sure if there were any things I should check first, the harness or any other common problems.
I was just about to order the assembly but thought I would check with someone who has more history with the G35 before I drop a few hundred bucks.
Thanks!
Ed
Thanks!
Ed
