Notices
2008 G35x Custom Halo Light DRL Problems
Old 01-21-2015, 05:22 PM
pnancollas's Avatar
Hi, I just bought a 2008 G35x that had a lot of stuff done to it. One of the things it has is custom halo lights. When I first got the car, the halo lights would always be on, except if the headlight control was in the Off position. I normally keep it on the Auto setting, so if it's light outside the lights are off, and if it's dark outside the lights turn on, but the halo lights would be on either way (like a daytime running light).
The guy I bought it from also had a lot of other electrical stuff installed that I didn't want. I was going through uninstalling everything that I didn't want, and now that I'm done, the halo lights won't turn on in the auto setting unless it's dark outside, and then all of the lights are on. It's as if I somehow disabled the daytime running lights. For the most part I knew what wires I was pulling out, but I have to admit, I made a couple of guesses because he had some things in there I hadn't dealt with before.
Does anyone have any experience with this? I disconnected the battery while working on everything, so it may have just reset some setting, or it might be something I unplugged that I wasn't supposed to. The only wires I cut or unplugged that I wasn't sure about were down by the fuse box by the drivers seat. Everything else in the car still works as normal. If anyone has any idea how to get the DRLs working again, let me know.
Thanks.
Old 02-03-2015, 06:34 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Pretty much you have to pull out the headlamp before you get a clear answer. The DRLs are going to have their own + and - for themselves (likely red and black). You should see the DRL wire coming out of the same lens cover as the headlight it is on.
Let me know your progress.
julian.dion
Lighting
07-29-2015 08:33 AM
rping
07-26-2015 09:53 PM
richmc
07-26-2015 08:13 PM
myaso
Lighting
07-22-2015 10:34 PM
newbdriver01
07-15-2015 06:10 PM
Quick Reply: 2008 G35x Custom Halo Light DRL Problems
