03 g35 sedan FOGS???
on the first gen models (03-05) the fogs are your brights. The fogs are inside the headlamp assembly. Since we have 1st gen HID's, they are only low beam. The fog's are dual filament. Low beam for fogs, high beam for, well, highs. The hid's stay on while the high beams are on. 2nd gen models have newer HID technology, and they are all bi-xenon, meaning they do not use the fogs for brights. There was also JDM fogs you could add to the bumper, but they are super duper expensive if you can find them, and a lot of people have deemed them tacky.
Are your aftermarket headlights hid or halogen? Were they direct plug in or did you modify wires? Regardless your headlamp is a single filament H1 (if halogen) or D2S (if HID) and the fogs are dual filament H4's so every time you flip the brights on, the H4 fog bulb will also light up.
Aftermarket heads
Another 03 Sedan User here,
Frostbite, are you saying that we have to turn on the brights, then turn on the fog lights to see them work?
no, the car shares the same bulb for fogs/brights. Look at this video I just took of mine. You can see how the lows are just the hid, then I activate fogs, then I activate brights. You can see in the video how much brighter the fog light gets when I turn the brights on. The fog light is just an H4 bulb, which is a headlight bulb on most other cars.
CalebAEvans (11-30-2015)
JOKER
02-26-2018 12:39 PM
JOKER
Interior
83
11-18-2017 10:55 AM
