Show Your Support Become A Premier Member
Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Only Vendor Threads | New Picture Comments | New Profile Comments |
Go Back   G35Driver > Tech Area - V35 > Interior & Exterior > Lighting
Sign in using an external account
Register Forgot Password?
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
submit to reddit
Thread Tools Search this Thread Rate Thread Display Modes
  #181
Old 07-24-2011, 03:21 PM
Points: 5,813, Level: 49
Points: 5,813, Level: 49 Points: 5,813, Level: 49 Points: 5,813, Level: 49
Level up: 32%, 137 Points needed
Level up: 32% Level up: 32% Level up: 32%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Garage is empty, add now
I was going crazy on how to get the headlight harness off, this info helped a ton
Quote:
Originally Posted by surma884 View Post
There seems to be wrong information about unplugging the harness and the DIY'er didn't explain it. Not a very good DIY.
So once you unscrew the 4 bolts on the headlamp if you try to pull the headlamp out it will not come out because the wiring harness is still plugged. There is not enough room to unplug it either. The reason is the connector is on a holster. It is secured to the headlamp so that the wiring harness doesn't move around. It is secured by sliding it on the "rail".
Here is how you remove it. When you are facing the headlamp, if you pull the headlamp out slightly you will see the connector. Use a flat head screwdriver and insert it between the connector and the headlamp. You will insert it to the side of the connector. You will use this screwdriver as a crowbar to slide the connector off. Tilt the screwdriver towards you so that the connector is pushed towards the back of the car. Once the connector has come off you can pull the headlamp out further and you will have much better access at unplugging the connector.
The release button for the connector is facing down so all you do is twist the connector up and then use a flat head screwdriver to push down on the release button and separate the connectors.
This is the proper way of doing it. I saw about 10 posts telling people to break it! That is not a good idea. The harness design is not bad, it was just bad information given out.
__________________
03 cb 6sp coupe jic magic/rotora/tein/injen/roja/rockchips/skunk2/megan
  #182
Old 07-25-2011, 05:15 PM
Points: 831, Level: 15
Points: 831, Level: 15 Points: 831, Level: 15 Points: 831, Level: 15
Level up: 31%, 69 Points needed
Level up: 31% Level up: 31% Level up: 31%
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks!
  #183
Old 08-15-2011, 10:34 AM
Mark2K8's Avatar
Points: 2,935, Level: 33
Points: 2,935, Level: 33 Points: 2,935, Level: 33 Points: 2,935, Level: 33
Level up: 24%, 115 Points needed
Level up: 24% Level up: 24% Level up: 24%
Activity: 14.2%
Activity: 14.2% Activity: 14.2% Activity: 14.2%
2005 Infiniti G35
Alright I'm kinda stuck...
I'm on the very last part of removing the headlights off the car, but not sure what to disconnect (what wires).
Which of what do i take off and how?
(Also, i read that post expaining it and still dont get it...)
__________________
2005 DG G35 Coupe
  #184
Old 08-15-2011, 04:07 PM
Points: 2,452, Level: 30
Points: 2,452, Level: 30 Points: 2,452, Level: 30 Points: 2,452, Level: 30
Level up: 2%, 148 Points needed
Level up: 2% Level up: 2% Level up: 2%
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
2004 Infiniti G35
In the first pic do you see that big black plastic connector? You need to separate that. There is a little button you press down hard with a screw driver to separate the connectors.
__________________
2004 G35 Coupe - DG, Nav, Spoiler
  #185
Old 08-15-2011, 04:09 PM
Mark2K8's Avatar
Activity: 14.2%
2005 Infiniti G35
Yea I got it. Did it in one side, but in the other side that button flew/broke lol.
__________________
2005 DG G35 Coupe
  #186
Old 08-15-2011, 04:14 PM
ME GUSTA's Avatar
And then. Asparagus.
Points: 6,670, Level: 53
Points: 6,670, Level: 53 Points: 6,670, Level: 53 Points: 6,670, Level: 53
Level up: 60%, 80 Points needed
Level up: 60% Level up: 60% Level up: 60%
Activity: 99.3%
Activity: 99.3% Activity: 99.3% Activity: 99.3%
1995 McLaren F1 LM
That plastic connector should just seperate into two. And that should release the headlight. That's the only thing you need to remove.
It was a pain in the arse seperating it. That clip really doesn't want to be pushed down.
__________________
Street Wheeler
2005 6MT Coupe - Midnight Purple Pearl
  #187
Old 09-12-2011, 01:02 AM
akoustic's Avatar
Points: 2,502, Level: 30
Points: 2,502, Level: 30 Points: 2,502, Level: 30 Points: 2,502, Level: 30
Level up: 35%, 98 Points needed
Level up: 35% Level up: 35% Level up: 35%
Activity: 6.0%
Activity: 6.0% Activity: 6.0% Activity: 6.0%
2004 Infiniti G35
okay. I had to replace my headlight with another one because of broken tabs... this is a great thread with good info but I did run into the same problem with the harness. The trick is, just get a flat head screwdriver and pry out the gap between the male and female harness connector. They come apart fairly easily. My harness hasn't been disconnected for 6+ years and it came off without much effort.
I spent most of the time trying to get the bumper to loosen... other than that, fairly easy DIY.
Cheers!
__________________
04 Coupe 6MT Black/Black | DBA 4000 Slotted | Hawk HPS | Motul | Michelin PS2
  #188
Old 09-19-2011, 02:45 AM
Trickstyle's Avatar
Points: 2,218, Level: 28
Points: 2,218, Level: 28 Points: 2,218, Level: 28 Points: 2,218, Level: 28
Level up: 46%, 82 Points needed
Level up: 46% Level up: 46% Level up: 46%
Activity: 4.4%
Activity: 4.4% Activity: 4.4% Activity: 4.4%
2003 Infiniti G35
My Garage
Bukakke_For_You Steezy777
Cheers!
+1 when i did my H4's i had a hella hard time getting that connector loose(45mins), i almost gave up until some random guy walked by and he suggested a pliers(to hold the clip down) and a screwdriver(to pry em apart) worked like a charm...
  #189
Old 10-25-2011, 05:51 PM
Points: 4,536, Level: 42
Points: 4,536, Level: 42 Points: 4,536, Level: 42 Points: 4,536, Level: 42
Level up: 93%, 14 Points needed
Level up: 93% Level up: 93% Level up: 93%
Activity: 2.5%
Activity: 2.5% Activity: 2.5% Activity: 2.5%
2005 Infiniti G35
Hey just wanted to say thanks for the DIY guide. I just swapped my old headlights on my 05 for some 06 projectors and I really appreciated it.
  #190
Old 04-15-2012, 03:21 PM
Points: 2,666, Level: 31
Points: 2,666, Level: 31 Points: 2,666, Level: 31 Points: 2,666, Level: 31
Level up: 44%, 84 Points needed
Level up: 44% Level up: 44% Level up: 44%
Activity: 3.5%
Activity: 3.5% Activity: 3.5% Activity: 3.5%
Send a message via AIM to bnorris85
Quote:
Originally Posted by buercky View Post
This was GREAT show me type.... Got my long extensions on my 10mm made those 2 screws on the front 1\4 panel come out very easy.
I also put tape the full length of the fender all the way to the tip and doubled it up to protect the paint.
Yeah i couldnt get a socket to reach and stripped the screw and scraped the **** outta my finger...i then threw my socket at the house and my roommate yelled at me.
I quit and worst of all i can't even drink cause i gave up drinking for a month.
  #191
Old 04-16-2012, 03:42 AM
Points: 9,358, Level: 65
Points: 9,358, Level: 65 Points: 9,358, Level: 65 Points: 9,358, Level: 65
Level up: 3%, 292 Points needed
Level up: 3% Level up: 3% Level up: 3%
Activity: 3.1%
Activity: 3.1% Activity: 3.1% Activity: 3.1%
Now, if only i can find somewhere to buy a clear lens for the amber that is in the OEM (no projector) housings.
__________________
SDGZ & SDCE Club member! Move over Biotch, you drive like old people F***
  #192
Old 04-30-2012, 09:14 AM
LCA575's Avatar
Points: 11,541, Level: 70
Points: 11,541, Level: 70 Points: 11,541, Level: 70 Points: 11,541, Level: 70
Level up: 73%, 109 Points needed
Level up: 73% Level up: 73% Level up: 73%
Activity: 0.4%
Activity: 0.4% Activity: 0.4% Activity: 0.4%
AACstyle AACstyle
Quote:
You get the clear lens at no cost when you order the kit HERE
__________________
G35 Custom Lighting: AACstyle.com
submit to reddit
Tags
2005, baking, bulb, coupe, g35, guide, head, headlamp, headlight, headlights, infiniti, lights, painting, removal, remove, replacement
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
G35Driver.com | My350Z.com | MyG37.com | ZDriver.com |
Everyone's Contact Details
