MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Interior & Exterior > Lighting
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #121
Old 06-02-2009, 10:34 PM
nice, but what if you want to remove the entire front bumper? are there any more screws, clips, bolts that need to be unscrewed to get the entire thing off?
  #122
Old 06-02-2009, 11:33 PM
O HELLA OEM's Avatar
Im Going All Impul.
Send a message via AIM to O HELLA OEM
^probably a few bolts on the bottom of the bumper that you need to unscrew
__________________
Ohio G Club Member
**Ninja**
....Nissan Skyline 350GT....
  #123
Old 06-03-2009, 01:14 AM
YT35's Avatar
VROOMMM
2005 Infiniti G35
Quote:
just look under your car, you'll see the rest
  #124
Old 06-03-2009, 01:53 AM
i would, but i don't have much clearance to really get under there...
  #125
Old 06-16-2009, 07:20 PM
Trying to paint my headlights. I cannot get the headlight free from the car, I cannot see the clip that I need to unplug. Is it on the bottom of the harness and how exactly do I "unclip" it? Do I push it away from the harness? Any help is appreciated thanks =)
  #126
Old 06-16-2009, 07:32 PM
2005 Infiniti G35
Quote:
I had the same issue when I was trying to replace my bulbs. I just slipped the harness off the bracket it is attached to. That gave me enough room to take the headlight out. It wasn't too bad sliding it back on either. Hope this helps.
  #127
Old 06-16-2009, 07:40 PM
Ok, well, still can't get it out. The harness has a that little plastic attached on the top, and while trying to push it out, it broke. Now the harness is loose from the headlight, but still attached, How do I unclip it? I can flip the harness to expose the bottom(since that top clip is now snapped, and I can see the clip but I don't get how it works. How do i use the screwdriver to unclip it?
  #128
Old 06-17-2009, 01:48 AM
YT35's Avatar
VROOMMM
2005 Infiniti G35
the clips are on the underside, if you can rotate it, you can see it, if not, use a small mirror and put it on the bottom, you'll see where u should unclip, if it snapped, it should come off, theres like 2 little "stopper" clip holding it with the main clip, good luck!
  #129
Old 08-23-2009, 01:58 AM
thescreensavers's Avatar
2005 Infiniti G35
Send a message via AIM to thescreensavers Send a message via MSN to thescreensavers
any one know if this can be done with out an Extension piece, I don't have one :O
__________________
SFL G Club
05 OB SedanS |Z-tube|Clear Corners|
  #130
Old 08-23-2009, 02:15 AM
YT35's Avatar
VROOMMM
2005 Infiniti G35
Quote:
yeah you can, it might scratch your arm a bit though, wear some long gloves or have a friend help you pull it while u stick your hand in to unbolt
  #131
Old 10-29-2009, 10:16 AM
Anyone from western Maryland and done the demoneye installs before? I've sat here for 3 hours trying to get the damn light harness unplugged and am freaken tired of messing with it. I'll pay someone to install the AAC demon eye kit and will give you a hand where I can. If not, someone can buy my kit from me then.
Last edited by blackhat5; 10-30-2009 at 03:30 PM. Reason: Not doing this myself anymore
  #132
Old 10-30-2009, 06:41 PM
Send a message via AIM to G2FLIP4
Ya the designers could have put the release clip on the TOP!!!! of the plug. Its a pain to get it and to unclip it.
Got mine out and the oven is preheating right now. w00t!
  #133
Old 10-31-2009, 12:48 AM
If you're really frustrated, just break the piece that the harness slides onto.
Then you can rotate the harness and unclip it.
When I put my headlights back in, I didn't even slide the harness back on (I was able to unclip without breaking anything so the slider is still useful) because it'll make things much easier in the future.
  #134
Old 10-31-2009, 05:29 AM
YT35's Avatar
VROOMMM
2005 Infiniti G35
so there's actually an easlier way... i foudn out -.-
you know how the chip is slipped on to a bracket on the headlight, just pull the whole harness of that clip towards the rear of car, it'll break off and makes everything much easier
__________________
DG!
  #135
Old 11-05-2009, 06:18 PM
exactly what i did, just broke the harness...
Tags
2005, baking, bulb, coupe, g35, guide, head, headlamp, headlight, headlights, infiniti, lights, painting, removal, remove, replacement
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
