Notices
G35 Coupe Headlight Removal Guide (3 Simple Steps)
Old 10-29-2012, 12:08 AM
nbarkins's Avatar
Originally Posted by importroller
Now, if only i can find somewhere to buy a clear lens for the amber that is in the OEM (no projector) housings.
go to any hardware store, lowes,home depot,ace,etc etc. Buy a sheet of plexi glass, cut it out using a stencil of the amber one cut out of paper, wam bam!! now u have ur own.(and save crazy amounts of money! they make diff color plexi glass, so u can make a "custom" look if you wish. u can also do this with the compass/temperature display, to get rid of the ugly orange color and plastic!
  #197
Old 10-29-2012, 01:53 AM
SAMzG35's Avatar
G35
What the man above said, plexi glass will do the job. You will also need a silver coated amber turn signal bulb or SwitchBack LED bulb. other wise it'll always have that amber look to it
Also in 03-05 housing you can use any projector 2.5" lens
Originally Posted by nbarkins
My 06 projectors don't have a bulb or even a bulb space, in the cealrance strip why would that be?
Clearance strip is only in 03-05 reflector type housing. 06+ projector headlights dont have them
Originally Posted by Jwms
Do you have to open the case to Chang the bulbs? How do you re-seal them?
No you dont, two ways to change bulbs, either from wheels wells or by removing front bumper. Once you have access to the back of the headlights there will be a cap behind each bulb, Twist off and replace, Pretty straight forward.
However to install CCFL tubes, rings or LEDs inside the housing you do have to open the housing.
nbarkins (10-29-2012)
  #198
Old 10-29-2012, 03:36 PM
nbarkins's Avatar
im not sure why i asked that question about the clearance light the way i did, but ty for the response
  #199
Old 06-29-2014, 11:36 AM
PLENUMCOUPE's Avatar
Hhh
  #200
Old 08-19-2014, 04:44 PM
sdwhatley's Avatar
I'm planning to take off the bumper and remove the headlights today but for some reason the images no longer show up with the original DIY write-up. Any ideas/alternative instructions?
  #201
Old 06-26-2015, 11:47 AM
Patrick Bovee's Avatar
Having the same problem. I have a Oracle halo kit for my 06 coupe. I'm trying to find someone to install them. He asked if I can take the headlights off myself then give it to him. Is there anyway to get those pictures?
  #202
Old 06-26-2015, 01:00 PM
hdmark's Avatar
its pretty easy, just drop the front bumper and then there are 3 or 4 bolts holding the headlights in. remove the bolts, pull the headlight up a little, and disconnect the wire harness
  #203
Old 02-01-2016, 05:51 PM
Shawn Tooley's Avatar
Why can't I see pictures in the post?
New to the forum... Why can't I see the pictures in the post?
  #204
Old 02-01-2016, 05:58 PM
JOKER's Avatar
CLUB MODERATOR
because it's from one hundred million years ago and pictures went extinct with dinosaurs.
  #205
Old 02-01-2016, 06:55 PM
Not asking for a "VHS" or "Super8" of the operation
But pictures (e.g. jpg, etc) are still fairly standard. Are you saying that because the original post was so long ago, pictures have been removed or deleted? Do I need to upgrade to premium in order to see pics?
  #206
Old 02-02-2016, 12:23 AM
JOKER's Avatar
CLUB MODERATOR
Original poster must have removed the picture from their original hosting location. So they are no longer shown.
  #207
Old 02-02-2016, 08:56 AM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
This is why people should use the built in photo wizard to house photos for DIY's and such.
  #208
Old 02-02-2016, 11:16 AM
JOKER's Avatar
CLUB MODERATOR
back in those days the system was slightly more retarder than it is now. So hosting pictures on driver was not always an option.
  #209
Old 02-02-2016, 12:01 PM
SAMzG35's Avatar
G35
Ahahaha
  #210
Old 02-03-2016, 12:06 PM
That's true, there are other threads about this but I could get detailed photos of this procedure when I pull a g apart next month.
Quick Reply: G35 Coupe Headlight Removal Guide (3 Simple Steps)
