WTB: 3rd brake light - rear wing brake light for coupe
Old 02-16-2017, 06:52 PM
BradMD_96's Avatar
Like the title says, on the lookout for a 3rd brake light which fits in the wing.
Mine is broken.
Thanks!
Old 02-16-2017, 09:32 PM
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
Make a call or visit your local Infiniti/Nissan bone yard (wrecking yard) for the parts you need! Even if a car is hit in the backend the 3rd brake light might be intact and cheap.
Gary
Old 02-16-2017, 10:25 PM
Urbanengineer's Avatar
Received 1,016 Likes on 935 Posts
The light doesn't show? If so, check if the wiring to the trunk went bad at the body to trunk connection (inside the rubber).
Old 02-19-2017, 03:16 PM
BradMD_96's Avatar
Oh, no it's like physically broken. And also the lens is completely opaque.
Up until now I suspected it may have been a dummy replacement because the lens was completely opaque like a normal piece of plastic.
Only now, one side is broken/falling off and I could see some LED's inside.
I might actually just put it together and spray it the same red on the tail lights because I think to replace entails removing the wing - right?
