| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Heat pump vs AC and gas heater question
My house's central heater is broken and I am thinking to add a ac unit as well. I look online and heat pump seems to do both of the work. Is it efficient to use something like that at home? Reliability? I live in california so, it always cool at night. We mostly likely will use the heating more than cooling.
Do you have you gas with PG&E?
We offer rebates for furnaces. http://www.pge.com/myhome/saveenergy...ce/index.shtml They have some pretty efficient furnaces out there.
__________________
"It's the kind of love that touches you... and makes you feel alive. I want you to know that you can find someone to touch you... the way I've been touched." - Friend of mine |
I got this off some site!
How Much Can It Cost To Heat My Home With A Gas Furnace Vs. A Heat Pump?* House Built To State Energy Code Efficiency Level Gas Furnace Cost/Year $1033 Heat Pump Cost/Year $666 Heat Pump Cost Savings/Year $367
__________________
'06 5AT OB Coupe Premium Pkg - Axis Matrix 20x9/20x10.5 Stock Height
If you don't have a gas line and your stove, water heater, etc. are all electric....then you have no choice but to get a heat pump. I think heat pumps starts to struggle at really cold temperatures though where it's constantly running to heat up your home. You probably get mild winters anyway in Oakland so the heat pump should be good.
__________________
Stock 03 Diamond Graphite, 6MT coupe, stock 18" wheels, everything else...you guessed(guest) it, plain bone stock...maybe Last edited by Deezflip; 08-21-2009 at 10:54 AM. |
Quote:
__________________
Lipstick, heels, and mod-itis. 2006 IP Coupe | Fast Intentions | JLine SDMrl2 | 3M |
Heat pumps can be great in the right application.
We've built 4 homes in the last 25 years. I've had three types of heating systems......
Pro's for heat pump.....
Con's for heat pump.....
With those cons in mind, I'll mention that most of those negatives can be overcome in a big way by moving from an air sourced heat pump to a ground sourced heat pump.....geothermal. That's what we had in our PA house. It's quite a bit more expensive up front because you'll be drilling vertical wells and sinking casing or laying in a field of horizontal pipe sort of like a leaching field. Ours was a vertical system. However, after the system is purchased and installed the efficiency is such that you can basically set the temp anywhere you want summer or winter for little cost. You are pulling heat from the earth which is at a stable 50 - 60 deg or so. That's right in the sweet spot for a heat pump's heat exchanger. I love ground sourced heat pumps. Last edited by SpudRacer; 08-21-2009 at 08:38 PM. |
| Tags |
| ac, heat, pump |
| Thread Tools | |
| Display Modes | Rate This Thread |
