The M-Spot For General discussion of the M35/M45
problem with my HID after new bulbs.help
Old 04-26-2010, 06:59 AM
vortech gt's Avatar
took the car to my local shop to have one the bulbs replace after one went out a few days ago.got the replacments and now at night i can barely see the road.bulbs are same.is there a right or wrong way to install these ? it was daytime so i had no idea it was that bad untill i drove the car that night.what can i do ?
thanks
Old 04-26-2010, 07:17 AM
EnJoiLuv's Avatar
Did you make sure the shop ordered the right bulbs? 4300k phillips?
From what i read, it seems that the shop you went to tried to screw you over and bought cheap bulbs.
had the same problem with my car, i thought the problem was the ballast, but it was actually just the bulbs.
Old 04-26-2010, 09:35 AM
vortech gt's Avatar
bulbs are the same,the drivers side light cuts off like 6 ft.the passenger side is fine.i would hate to adjust it since it was fine prior to the new bulbs
Old 04-27-2010, 12:43 AM
EnJoiLuv's Avatar
i would suggest adjusting it because whenever you touch your headlights, its going to get misaligned. Adjusting is actually fairly simple. Just take a screw and turn right to go lower and left to go higher.
There's a thread here somewhere that shows you how to adjust your headlights. There's also a video about adjusting headlights on youtube.
Old 04-30-2010, 07:21 AM
vortech gt's Avatar
is there a right and wrong way to replace the bulbs ? it seems light the bulb is angle upwards inside the projector.i'm going to take it back to them this sat.
Old 05-01-2010, 07:56 PM
Manual G's Avatar
Once they fix it, find new a shop.
Kelvin Style006
05-23-2016 03:47 AM
mattdg35
09-14-2015 11:28 AM
G35-2004-mt6
09-11-2015 04:16 PM
twentyeggs
09-11-2015 03:58 PM
Quick Reply: problem with my HID after new bulbs.help
