MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > General Discussion > G35 Sedan V35 2003-06 > Media Share G35 Sedan V35
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 11-14-2009, 09:38 PM
bbs350z's Avatar
geerider your rims look sick lol.
this kinda reminds me of my 350z's build. the worst thing is waiting for parts lol.
and gtm clutch pivot ball ftw.
in for numbers
__________________
*03 350z built tt *04 350z track whore *03 g35 sedan procharged soon
  #32
Old 11-18-2009, 10:52 PM
Nickk6's Avatar
hellafunctional
2005 Infiniti G35
Send a message via AIM to Nickk6
I will give a final update with pictures and everything after I tune the car. Should be before the years end if traveling doesn't get in the way. I need to wait for everything to be finished because I have some serious bashing I need the post up and don't want to step on my toes.
Andrei: The CJM twin pump required some modification to fit. Unfortunately I only have pictures of a rough piece I designed to hold the sedans level sensor. Charles @ CJM was extremely helpful giving me info I otherwise would not have known!!!
The exhaust isnt going so well, the Megan Y-pipe doesn't fit onto my downpipes and its 2.5 inch inlet which won't work so well with the boost. My exhaust guy won't work on cars without catalytic converters, which is also another little snag.
Axles and stuff will all get upgraded down the line, my wallets a bit dry at the moment.
WHat do you mean is the HKS ems locked? I don't think so, should be able to add maps and tune no problem.
As far as the coolant hose I wasn't worried about hiding, tucking or removing anything. All the other coolant lines that go to the throttle body and oil cooler got blocked off and are no longer in use.
bbs350z: the clutch pivot ball IS NOT necessary on a 2005+ G35 Sedan, I am not sure about the coupes, but the pivot ball in the earlier Z's had a "neck" on it. The newer ones the ball is directly on the shaft and shouldn't break at all. Its also hardened.
2005+ G35 pivot ball
Z pivot ball
__________________
05 4DR 6MT - TWIN TURBO - FCON - COSWORTH - ROTORA - VOLK - HKS - MISHIMOTO - EXEDY
  #33
Old 11-19-2009, 12:09 AM
donpisto's Avatar
Get Like Me
Nick, if you need an exhaust guy, I know of one. Labree Motorsports in Canoga Park, but that might be a little far for you. Call him up, name is Brent, and he'll help you out.
__________________
Team OutCast Gs - Human Resources Director
www.streetworksauto.biz | www.teamoutcast.net
I Got The Hook Ups on Universal Air Suspension & Camber / Toe Arms
  #34
Old 11-19-2009, 04:20 AM
bbs350z's Avatar
Quote:
Originally Posted by Nickk6 View Post
IAndrei: The CJM twin pump required some modification to fit. Unfortunately I only have pictures of a rough piece I designed to hold the sedans level sensor. Charles @ CJM was extremely helpful giving me info I otherwise would not have known!!!
Z pivot ball
yea i have a cd009 on w/ a built 06 revup motor on my z. the clutch pivot ball i recieved (i rember being 2 options for the years), looked like the top one for the g. also charles is the man, im sure he can help you with any of your fcon needs, as he is with mine. im located in wi though so hes alot closer. as far as his twin pump, lmk how that works out. i currently have sp's triple on 1200cc's and it wasnt too bad of an install. most of the electrical portion of that was handled by zach @ sound performance because im terrible with wiring lol. im really looking forward to seeing your build. the one thing i left out was a fluidyne dampner which ill be getting soon enough. where exactly are you located?
on a side not, i havent heard such great stories about the turbos gtm uses in their kits. this could all be rubbish but im in to see how they hold up.
heres a pic of the sp triple.
__________________
  #35
Old 11-20-2009, 02:13 PM
Andrei's Avatar
Good to see the fuel setup fit. The HKS EMS was locked last I checked and could only be installed and tuned by a registered tuner.
Quote:
Pros
* Full control over everything
Cons
* Only a handful of HKS Pro-Dealers available to tune this EMS
BTW. You can get an exhaust from the coupe or Z and extend the pipes to make it fit. There are a few places that make 3" setups. http://www.alteredatmosphere.com/mm5..._Code=350Z_EXH
http://www.gtmotorsports.com/home.php?cat=255
  #36
Old 11-22-2009, 12:29 PM
Nickk6's Avatar
hellafunctional
2005 Infiniti G35
I wish I did this on a Z, I had to fabricate a custom aluminum bracket for holding my level sensor and then it was a bitch to install. Also for getting fuel from the other side of the tank, that line didn't fit on my pump so that had to be modified.
Here is my pump with the first bracket (took one redesign to get it to fit)
The redesign was shaved down in half and the sensor was moved down almost 1/2 inch.
__________________
  #37
Old 12-22-2009, 02:04 AM
Nickk6's Avatar
hellafunctional
2005 Infiniti G35
more to come...however I sadly realized I lost a ton of images from the build
__________________
  #38
Old 12-22-2009, 03:04 AM
bbs350z's Avatar
so sick. cant wait for numbers and vids.
__________________
  #39
Old 01-02-2010, 02:45 AM
Andrei's Avatar
That looks good. Eliminate the coolant hose running across the timing cover. It makes it run cooler. You might also be interested in this http://www.my350z.com/forum/engine/3...g-package.html Check prices with GTM and Forged Performance. It's a mod that is well worth for a high dollar build like yours. Also check http://www.courtesyparts.com/ if you want to buy the parts directly.
^Actually it looks like you already have that mod?
Also check http://my350z.com/forum/forced-induc...the-bad-7.html
Did you fabricate an exhaust? I would just run it with the downpipes open if you don't have an exhaust yet. Running a small exhaust is going to increase temps. I saw a big difference in engine bay temps with my dual 3" exhaust since the exhaust gasses exit so quickly.
Also check http://my350z.com/forum/forced-induc...erheating.html > guy has air in the cooling system and doesn't know.
  #40
Old 01-02-2010, 04:15 AM
bbs350z's Avatar
+1 for update and awesome info from andrei
__________________
  #41
Old 01-02-2010, 01:24 PM
wow thats so sick....is that a solid transmission mount? or am i confused? (oh and sorry if its mentioned somewhere else i didn't see it)
__________________
  #42
Old 01-05-2010, 07:20 PM
CandlestickPark's Avatar
Resident Nikonian
2005 Infiniti G35
Nick I'm hoping that we get an update from you soon, I see you are creating a new thread.
Nickk6 is online now
hellafunctional
Last Activity: Today 03:25 PM
Current Activity: Creating Thread Engine, Drivetrain & Forced-Induction
__________________
05 Lakeshore Slate Sedan
SxExCx - Stage4 Performance - rookie - RRYDE
  #43
Old 01-08-2010, 12:03 PM
Andrei's Avatar
Any updates?
Quote:
That is a stock brace that was used to with the stock catalytic converters.
  #44
Old 01-08-2010, 10:58 PM
Nickk6's Avatar
hellafunctional
2005 Infiniti G35
hellafunctional
LOL, sadly I was going to post a question regarding my car not starting, but I am just going to take it to a local shop and see if they can figure it out. The car turns over but I wasn't getting any spark. So I put the coil back in and then went to start it. The fuel pumps didn't turn on, parking lights came on, windows and horn quit working. Pulled the F-CON and still the same problem, opened the ECU and BCM, no burns... I've checked almost every wire in the engine bay and car as well as all the fuses and relays and nothings wrong. I couldn't trace those problems to anything starting with simplest first, windows not working...just left stumped. I hooked a scanner up to the car and it had no communication with the ECU.
As soon as thats sorted I will have #'s
__________________
  #45
Old 01-08-2010, 11:15 PM
Resident Nikonian
2005 Infiniti G35
Dang sorry to hear you are having those issues. Hopefully you get everything straightened out soon!
__________________
Tags
g35, g35driver, half, line, nickk6, vacuum
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
