Hello and HELP!!!!!!!!!!!!
Recently picked up a 03 g35 sedan to replace the 89 saturn wagon I drove into the ground. I've had the g35 for a little over a year and love it until recently. Have had a major issue with the damn thing overheating! I'll drive about 2 to 5 miles down the road at around 50 to 55mph and the car will hit full overheat in no time. I've replaced the radiator, thermostat, water pump, fan clutch, radiator cap and plug and had about 15 burping sessions with the same result. The overflow tank is not clouded and oil is fine.
My local mechanic is at a loss as to what else to do. HELP!!!!!!!!
I drove ttrank's car solo
Received 1,486 Likes
on
Have you checked the fans to make sure they're working properly? Did you test the thermostat before you installed it to make sure it works properly? Are both of your radiator hoses hot when the engine is fully warmed up? Does the heat blast when you crank it up? If the answer is yes to all of these questions then you might have a blocked heater core or a ghost in the machine. Good luck figuring it out and make sure you bleed the car correctly using the bleeder screw at the back passenger side of the engine bay.
on
