NorthWest Serving AK, ID, OR, WA
06 Infiniti g35coupe Overheating and no heat in cabin..
Old 05-29-2014, 10:15 AM
TheDizzle's Avatar
Awesome! I love threads with a happy ending! hehe
Old 05-29-2014, 10:48 AM
g35cooper253's Avatar
Not so happy right now lol i got off work about 1hour of driving between freeway and some test drive, the gauge started acting up again! but longest i ever driven without getting overheat...it takes a while to get to the Hot but when i dont drive it hard its start to come back down a bit but still working its way up to H. Then when i got home i check the overflow and its gotten higher then i think it should be...hmmm i dont know whats wrong now maybe i need to burp it some more today? im guess there is still some air in the system...but definitely a big progress comepare to before.
Old 05-29-2014, 10:50 AM
"I'm still curious though, before you brought it to the mechanic and spent 800 bucks. Was there any work you know of done on the cooling system?"
i did replace the thermostat at home but still overheated so i went to the mechanic shop and thats when they replace radiator and re"did" thermostat just to make sure it wasnt a faulty one.
Old 05-29-2014, 10:53 AM
coffeysm's Avatar
Ahh okay, so you probably introduced air into the system when you did the thermostat yourself.
Are your cooling fans spinning? After the car has been running for awhile pop the hood and listen to see if the fans turn on. You can try burping the system some more, but I've never had a problem before after getting hot air at idle. It's scorching heat right not just kinda warm?
Old 05-29-2014, 11:04 AM
ill let the car cool down while i get some sleep but i will test it again once i wake up to see if its just kinda warm or scorching. and yes my fan does come on its kinda hard not to notice it beacuse its audible while driving. i will keep u guys updated!
Old 05-29-2014, 04:12 PM
So while idling today I did get hot air blowing but I'm re-bleeding it now again trying to get some more air out hopefully this works
Old 05-29-2014, 04:19 PM
coffeysm's Avatar
Anyway you can get an ODB2 scanner or IR thermometer? So, you can get an actual reading of the coolant temp and compare it to what the computer thinks?
If it's still overheating then either there is more air, bad temperature sensor, or something worse like a head gasket. I did see a video recently where a mechanic was having a similar issue and the water pump fins were rusted down to nothing. So, the car would start to overheat and it was because it couldn't push enough coolant through to cool it. I don't think that's a problem here, but it could be?
Old 05-29-2014, 04:43 PM
Hmm the 2nd time I turn on heat at idle after getting air out of bleeder valve now heat just blows air
Old 10-01-2018, 11:47 PM
Worthy74's Avatar
I know this thread is old but did you ever figure out what the issue was? Head gasket or air? I’m in same boat
gatorglaze
09-10-2015 12:03 PM
TrillO.G.35
09-05-2015 02:06 AM
derres
08-28-2015 03:27 PM
CrazyLogic219
08-13-2015 06:40 PM
yassy
08-03-2015 12:24 AM
Quick Reply: 06 Infiniti g35coupe Overheating and no heat in cabin..
