Rambo's LS1 Build
  #61
Old 12-08-2011, 07:22 PM
Rambo's Avatar
I have to send it back and have them replace it. This is really the last thing I need to start doing the short block...kinda pissed about it but what can I do..
  #62
Old 12-08-2011, 08:09 PM
ryamartin's Avatar
cant go to the retail store for instant exchange??
  #63
Old 12-21-2011, 06:39 PM
Rambo's Avatar
Just bought a piston ring filer and a ring compressor tool. Lets see if they come in with all the pieces
  #64
Old 12-21-2011, 07:02 PM
g-adabout's Avatar
saweeeeet! I am off the next two weeks....hopefully we can hang out or sometime in the near future and talk V8s!
  #65
Old 12-21-2011, 07:35 PM
Rambo's Avatar
sounds good I should be in cinci on the 30th
  #66
Old 01-01-2012, 05:53 PM
Rambo's Avatar
So got a new bore gauge for christmas with all the parts. Pace performance is shipping the ring filer and compressor this week...I am going to start assembling the crank this up coming weekend.
  #67
Old 01-01-2012, 07:10 PM
g35man04's Avatar
CLUB MODERATOR
sweet man! my ls block is at my buddies shop, FAST intake manifold purchased with Fast fuel rails, Heads are being picked up next!!! hopefully within the next week or so.
  #68
Old 01-01-2012, 07:26 PM
Rambo's Avatar
Did you buy it new and did you get a FAST 102 or a 90? Where did you get it from? I am scrounging around on LS1tech for a used one.
What heads are you going with? I got a set of 243s with plans of having them ported later down the road. BTW if you are getting 243s make sure they are the ones with the triangle casting cooling marks they produce 5-6 more HP than non-marked heads.
  #69
Old 01-01-2012, 07:30 PM
g35man04's Avatar
CLUB MODERATOR
nope I picked up a FAST 78MM With ported throttle body Fast Fuel Rails, injectors, ports for Nitrous off ebay. People as still asking 1000-1200 for the FAST 102 or 90mm intake manifold itself thats just to damn much IMO. Precision Race Components Stg. 1 LS6 Heads & Cam Package
http://www.texas-speed.com/p-1160-pr...m-package.aspx
my power output is only going to be around 400-420 ish which is fine for me personally.....i am not going ***** to walls right now. my ls block also has an upgrade underdriven pulley.
  #70
Old 01-03-2012, 10:11 PM
Rambo's Avatar
not a bad deal are you just getting the cam and heads or the oil pump and rods as well?
  #71
Old 01-03-2012, 11:20 PM
g35man04's Avatar
CLUB MODERATOR
Rods also and already picked up ls6 ported oil pump. Picked up 36lb injectors yesterday. Made a really good contact that has deeper discounts than Texas speed. Sometimes 2-300 cheaper than some.
  #72
Old 01-06-2012, 10:35 PM
Rambo's Avatar
Just picked up a new LS2 90mm TB for my build. I will be upgrading the LS6 to alot of the LS2 stuff.
  #73
Old 01-07-2012, 07:41 PM
BuckeyeG's Avatar
Whats the diffrence between the diffrence between the LS2 stuff and LS6 stuff.
  #74
Old 01-08-2012, 08:08 AM
issues's Avatar
hey bro, been reading the thread and keeping up with your progress. hope all is good. I'm also working on a swap but opted for the lq iron block for strength. I cheated though and ordered mine from a ls specialist (not lazy, just not sure of myself to rebuild from scratch, lol) . I went with options that put me around 525 hp. Anyway wanted to say good luck and keep up the posts.
  #75
Old 01-08-2012, 08:55 AM
Rambo's Avatar
Well, the LS2 is a 6.0L and LS6 is a 5.7L, but they have alot of interchangeable parts with LS6 stuff being alot better than the LS1 stuff and improvements with the LS2 stuff over LS6 stuff. The heads between the LS6 and LS2 are exactly the same parts and set up.
The 90mm TB is a vast improvement over the 78mm TB on the original LS6. The LS6 corvette motor was drive by wire like the LS2 is.
I will also be using an LS2/LS6 Valley cover and an LS2 front cover (has cam sensor in front of motor instead of in the back) and LS2 timing chain which is stronger the the LS6 chain.
Also, should have an update later today with pictures.
Quick Reply: Rambo's LS1 Build
