| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Wow! Look At these 1/4 times.
I was searching around to compare 1/4 mile times of the IS350 and 2007 G35. I found this site that has nothing but drag times and punched in the IS350. There are people getting 13.1 with just an exhaust! When the aftermarket hits for theses cars they will be in the low 12's easy. And this is with an auto!
Here is the link. When you go there you can also click on the time and it shows you the time slips. http://www.dragtimes.com/results.php...arch+DragTimes
A 105mph trap is healthy indeed, but look at the timeslip; that was in February. It was probably excellent weather. No IS350 with just an exhaust is going to trap 105+ in 80 degree weather.
I'm not taking anything away from the car; it's obviously faster than the current G.
__________________
05 6MT Sedan. stock airbox, ztube, mrev, ichiba headers, kinetix pipes, stillen gen1 catback, Clutchmasters Stage1+JWT Fly, utec tuned by sharif + BFG's = 13.264@103.96mph in 975 feet DA |
Another note - notice that while it's trapping 105 in the 1/4, it's trapping 84 in the 1/8; it's only picking up 21mph in the top-end. If you look at the gearing of the IS, it's more aggressive in the first 3 or 4 gears than the g. I bet if a tock IS did a top-end run against a stock g from a roll(in a controlled environment of course
), it would be a dead heat.
__________________
Quote:
What does the IS put to the rear tires? I could see high 13s. I'm guessing gearing is a major factor here, given the 105mph trap speed. I would have expected something closer to around 110mph with that trap time. I'll be very impressed if an IS350 can do a low 12s without a basketball sized turbo or two. And even then traction would seemingly be a major issue on that car. Low 12s is 997Turbo/C6Z06 territory=- I'm sorry, I just doubt we'll be seeing IS350s there without some serious high-dollar mods. Here are some test results from Edmunds: Quote:
Quote:
I don't believe this...
__________________
105k miles and still going...
Ryan - 04 DG/G G35c 12.25 @ 116mph |
Quote:
It doesn't make sense, whereas 13.7 @ 104mph does. MT returned 13.9 @ 103mph for the G35, so it isn't far behind. And I do believe that in the higher gears, I think the new G35 would start to pull on the IS. |
Quote:
Although a 13.1@105 is hard to swallow with a 1.996 sixty foot. It's all in the gearing.
__________________
iirc it was not gutted.
in any case, the car just seems to launch really well... and 260-ish whp with gearing to match just seals the deal
__________________
http://www.streetseen.vi || 2004.5 G35C 6MT || Volk - Michelin - HKS - Stillen - Alpine - JL |
Quote:
__________________
08 G37S 07 G35S |
My IS350 put down 274whp and 245Wtq
the guy who ran 13.1 had an LMS exhaust, fully gutted trunk, and remvoed rear seat. |
The slowest time on that list is a 13.8....un freakin real!
Quote:
I highly doubt he gutted the car for every day use; probably just a track thing.
__________________
wow, just wow
__________________
Blackout! 03 5AT Sedan | Blacked out grill | Headlights | Corners | Door Handles | Blacked out Rays 19's | JWT Pop Charger + Z-Tube | 5/8 Skunk2 Spacer | Kinetix HFC | Coupe Middy | HKS Rear Section | Tein H-Techs.
| Thread Tools | |
| Display Modes | Rate This Thread |
