MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 10-24-2007, 07:51 AM
Send a message via Skype™ to NETSHARK
Nissan Japan GT-R Official Web Catalog
I took this info from the Official GT-R Japan Web Catalog, i translated some of the Info Using Babel Fish Translation tool, so some of the info might be corrupted due to the translation from Japanese to English.
Premium Midship GT-R:
Premium Midship Package
To ultimate "flat ride sport"
Compatibility of power train cooling and aerodynamic efficiency
Decrease of power train vibration
FR based 4WD generally loads the engine and the transmission on the front. In this case, the length which includes the transmission from the engine becomes considerable ones, in the rigid aspect becomes the disadvantageous material. Vis-a-vis this, separating the engine and the transmission, with the premium midship package which forms independent formation trance axle 4WD, it can decrease the vibration of the power train substantially. Furthermore because the transmission from the driver is categorized to the distance, it decreases also the confined sound near the driver's seat.
Driving position and utility
As for another advantage of this premium midship package, there is a point which can improve the operating environment of the driver. If past by the fact that the transmission which exists near the front seat foot is put on the rear, the foot space of the cabin expands. It became possible to arrange the pedal in ideal position. Because also the cabin guarantees sufficiently, the person of most physiques (height 144cm? Besides the fact that) it can sit down to 190cm, flat also the trunk space actualizes widely with the adoption of the run flat tire. Past there is no super car, height of the utility is held.
The engine VR38DETT :
NISSAN GT-R private new development VR38 twin turbo engine
3.8L V6 twin turbo MAX.POWER 353kw (480PS) /6400rpm - MAX.TORQUE 588N m (60.0kgm) /3200-5200rpm
IHI integrated turbocharger
The left and right bank of V type engine the turbocharger which is installed respectively NISSAN selected IHI make which time-honored racing machine. Utilizing the room of the aerodynamic volume displacement, 3.8L, after guaranteeing low-speed torque, unifying the exhaust manifold and the turbocharger.
Click here to see a video of VR38DETT Engine
Closed deck + rudder frame structure
Independent intake & exhaust system
The turbocharger, the intercooler and the catalyser - etc. it provides, 2 each adopting the inhalation and exhalation of air system which frees left and right bank each one.
Thermostat attaching oil cooler
The motor oil/oil cooler which cools the turbocharger makes air cooled system, in order always to control temperature optimumly, provides the thermostat. Furthermore, because the lubrication of the motor oil is maintained even in the kind of circumstance where G catches strong revolution with such as circuit travelling.
The Transmission GR6
GR6 dual clutch type transmission
Because basic important matter of the premium midship package which raises the basic efficiency of the vehicle that "it runs, bends, stops" to ultimate is satisfied, the transmission it unifies the 4WD system and mechanical LSD and loads onto the vehicle rear. It arranges the input/output shaft slantedly and by the fact that it converts flat, it has contributed to also center of gravity conversion low. In addition, the directly connected clutch brings, actualizing fast speed change with direct. The result of chasing after the packaging of ideal because the request which is required from NISSAN GT-R as a multiple performance super of 21st century car is actualized, those where it arrives, are the new development GR6 type dual clutch transmission. Linear actualizing running with direct in addition to controlling while it is mind with accelerator operation, with intense acceleration and the powerful engine brake with the control of direct connection of the ボルグワーナー make six plate dual clutch which does not have the slide, driving force. In addition, it corresponds to all travelling conditions the A range (automatic speed change), M range (manual speed change) with change, multiple performance promises the high performance. The speed change response where by the fact that paddle shift is adopted, operation of speed changing can do with M range, easily securely even in operational state of the extremity which receives intense front and back left and right G is fast is actualized. The GR6 type dual clutch transmission is designed to be the structure which respectively has the clutch in the odd level of 1,3,5 and the even number step of 2,4,6. For example, in the odd level the even number step selecting the gear beforehand while travelling, you wait. When the signal of speed change is received, the clutch is changed simultaneously instantaneously. In addition, because it corresponds to the paddle shifting which is continued, you adopted the high capacity triple cone synchronizer for all gears, economized also gear selection time to the extremity. Because of this, while it was throttle full opening boost pressure of the turbo was kept in high state, seamless and strong acceleration became possible to engine highest revolution. Furthermore, when shifting gear the synchronizer points to the engine rpm and the tire revolution, the running which is stabilized by the fact that sudden traction change is held down actualizes with シンクロレブコントロール. If at the time of corner penetration the downshift it does simultaneously with braking, with エンジンブリッピング the needle of the tachometer rises, with the accuracy which exceeds to the heel of the racing driver &, completes speed change instantaneously. In addition, in order to support these efficiencies, as for the GR6 type dual clutch transmission the craftsman/teacher who permits the assembly especially one does one hand composition, precision is guaranteed by the up-to-date inspection equipment.
Dry sump lubrication system
Even under high G condition of the high-speed cornering time and the like with the circuit, stabilizing, in order to be able to do the lubrication, transmission oil adopting the dry sump lubrication system which is injected directly to the gear.
GR6 type dual clutch transmission cross section diagram
The Aero Dynamics
The compatibility of Cd and down fourth
It tries if probably to decrease aerodynamic drag down fourth becomes sacrifice, if down fourth is preferred, Cd becomes large. So far, Cd and down fourth were in relationship of trade-off. But, in order to actualize the running which NISSAN GT-R aims, these compatibility are indispensable. The result NISSAN GT-R of repeating development Cd which 0.27 you call is a match to the racing machine (aerodynamic drag factor) with, actualized the powerful down fourth which is less than zero lift territories substantially. With this preponderant aerodynamic efficiency, as NISSAN GT-R raises the road-hugging of the tire in all scenes, can show the high performance by the fact that the grip which always is stabilized can be obtained without regrettable, also fuel economy efficiency of the extent which changes the image of the super car is achieved. As for the technology NISSAN to stack so far with development and the like of the FM package of course, the place where it contributes to the independent formation trance axle 4WD which this time is adopted with the premium midship package is large to the actualization of such aerodynamic efficiency. The air style which is introduced from the front grille by moving the transmission to the rear in one, it reached the point where it can let flow into the tunnel smoothly. This as it contributes to power train cooling greatly, is connected to also the decrease of aerodynamic drag. Furthermore, the bottom of the floor is rectified smoothly from the fact that it can designate the floor underside as flat, has made easy to produce down fourth.
Wind tunnel experiment (front)
Wind tunnel experiment (rear)
Carbon diffuser
__________________
2004 Desert Platinum G35 Coupe 5AT Mods: Nismo CAI V2, MD 5/16 ISO Thermal Spacer, UTR Resonated Testpipes, Fujitsubo Legalis R Catback Exhaust, UTEC (untuned) + Tuner WB.
Old 10-24-2007, 07:53 AM
The GT-R Specs
Oops I forgot to put the site this is the Japanese official site
http://www.nissan.co.jp/GT-R/R35/0710/index.html
Edit:
All the Specs are HERE !!!! Vehicle Weight Engine Specs, Transmission Ratios
http://translate.google.com/translat...language_tools
http://www.nissan.co.jp/GT-R/R35/071...00002nq3l.html
Engine:
■ engine model VR38DETT
種類・シリンダー数 Several types of cylinder DOHC・V型6気筒 DOHC V-6 cylinder
シリンダー内径・行程 Cylinder bore stroke mm Mm 95.5×88.4 95.5 x 88.4
総排気量 Total emission L 3.799
圧縮比 Compression ratio 9.0
最高出力 Maximum output kW(PS)/rpm KW (PS) / rpm 353(480)/6400 353 (480) / 6400
最大トルク Maximum torque N・m(kgm)/rpm M N (kgm) / rpm 588(60)/3200-5200 588 (60) / 3200-5200
燃料供給装置 Fuel system ニッサンEGI(ECCS)電子制御燃料噴射装置 Nissan EGI (ECCS) electronically controlled fuel injection system
使用燃料・タンク容量 Use fuel tank capacity L 無鉛プレミアムガソリン・71 Premium unleaded gasoline 71
Transmission:
transmission gear ratio final gear ratio
■ トランスミッション ■ Transmission GR6型デュアルクラッチトランスミッション(ファイナルドライブ一体型トランスアクスル方式) GR6 type DYUARUKURATCHITORANSUMISSHON (Final drive transaxle unified system)
エンジン Engine VR38DETT
変速比 Transmission gear ratio 第1速 The first speed 4.056
 〃 Turbo 第2速 Second speed 2.301
 〃 Turbo 第3速 Third speed 1.595
 〃 Turbo 第4速 Fourth speed 1.248
 〃 Turbo 第5速 The 5-speed 1.001
 〃 Turbo 第6速 The 6-speed 0.796
 〃 Turbo 後退 Recession 3.383
最終減速比 The final gear ratio 3.700
GT-R Weight Capacity
車両重量 Vehicle Weight kg Kg 1740(注1) 1740 (Note 1)
乗車定員 Riding capacity 名 Name 4(2+2) 4 (2 +2)
車両総重量 Gross vehicle weight kg Kg 1960(注1) 1960 (Note 1)
__________________
Old 10-24-2007, 08:08 AM
ttrank's Avatar
Hella fast...
2004 Infiniti G35
Wow!
Great find!
__________________
ONE FUN SEDAN!! MY CAR (LINK)
Detailed Image | Greddy Twin Turbo & Built Motor by UMS Tuning = 649whp/651wtq | Rotora (12/4pot) | IForged | Quad Projector Retro | 1-off Dual 3", Dual Muffler Turbo-back Exhaust by Nichols AutoFab | NITTO | SPARCO |
Old 10-24-2007, 03:24 PM
Thank You
__________________
Old 10-24-2007, 03:46 PM
the more down fourth, the better!!!
__________________
The strongest argument against democracy is a 5 minute conversation with your average voter. - Winston Churchill
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
