MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 04-07-2008, 01:31 PM
speedraver's Avatar
wassupMyNinjas! (^_^)
Motor Trend GTR vid! Awesome review! (^_^)
Track Test Vid:
http://www.motortrend.com/av/roadtes...t_first_drive/
Tech Vid:
http://www.motortrend.com/av/roadtes...ch_first_test/
Nissan GT-R Handling Test: Godzilla turns and stops as eagerly as he charges
By Frank Markus
Photography by Evan Klein
Having revealed Nissan's white lie about what's happening in its GT-R superstar's engine room and explained the science behind its magical acceleration, we set about scrutinizing Godzilla's chassis dynamics by putting it through our braking and figure-eight tests. Here again the fearsome monster laid down some fairly heroic numbers.
WHOA, BIG FELLA
The GT-R's brake hardware isn't overly exotic. The 15-inch diameter vented and drilled steel rotors, 1.3 inches thick in front, 1.2 in back, are of a floating two-piece design that helps to dissipate heat and prevents transferring it to the hub and bearings. Brembo calipers clamp with six pistons each in front, four in back, and use radial mounting to the uprights to reduce caliper flex (this race-inspired setup orients the mounting bolts parallel to the plane of the rotor, rather than perpendicular to it). The result: stops from 100 mph in just 280 feet, and from 60 mph in 105 feet. That ranks the GT-R in a three-way tie as Motor Trend's fifth best 100-0 stop in a regular production car.
100-0 mph (feet)
Dodge Viper SRT-10 274
Mosler MT900 Photon 275
Porsche Carrera GT 277
Ferrari F430 F1 (std launch) 278
Nissan GT-R 280
Dodge Viper SRT-10 Coupe 280
Porsche GT2 280
And if you thought the VR38DETT twin-turbo V-6's dyno readings of 507 horsepower and 500 pound-feet of torque were impressive, our computers suggest these Brembos are providing over 1200 horsepower worth of braking at the beginning of that stop. The PlayStation screen's braking-g trace plateau was around 1.20 g indicated, though our test gear pegs the peak g loading at closer to 1.35g. Most impressive.
TURNS ON A YEN
Early reviewers have been almost unanimous in their praise for the Nissan GT-R's steering feel, proclaiming it unusually communicative for an all-wheel-drive car -- especially one wearing big fat 255/40R20 meats in front burdened with 55 percent of the total weight. It's certainly no Porsche in terms of steering feel, but it's darned close to the BMW standard when threading up the Angeles Crest Highway (or drifting on Mt. Fuji, one imagines). Nissan attributes this (and the GT-R's handling in general) to the high-precision six-point mounted front and rear subframes. Structural rigidity at the rear is improved as a running change to all GT-Rs concurrent with the launch of the cars bound for the U.S. According to Nissan senior project engineer Bruce Robinson, this change improved steering feel and allowed the spring rates to be backed off just a bit, improving ride quality slightly.
__________________
Skyrine 350GT Coupe | Lakeshore Slate | Giggity-Goo | PLUR | Tig-O-Bitties | Ching Chong Eye | Manpuku BBQ | Hide Sushi | Yogurtland | Chadolbegi | Din Tai Fung | Youtube Search: Speedraver
http://rarejdm.com/speedraver1
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
