MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 06-07-2008, 02:25 AM
2005 Infiniti G35
How to change the power steering & brake fluids on a 2002 mustang.
Just like the tittle says, I need to change the Power Steering fluid and brake fluids on my girlfriends V8 mustang. Before I go on a long and probably fruitless search on the net for these topics I thought I would ask here. Maybe other mustang owners can point me in the right direction. I've worked on cars before but these fluids (brake & power steering) are uncharted territory for me. If you guys can include pictures that would be awesome.
Thanks in advance for the help.
__________________
Central Texas VQ Car Club established in January 12, 2008.
centexvq.com
Old 06-07-2008, 11:30 AM
2005 Infiniti G35
nobody?
__________________
centexvq.com
Old 06-07-2008, 11:38 AM
InTgr8r's Avatar
Administrator
2008 Infiniti G35
Power steering is a hydraulic system, it doesn't see the heat cycles of the brake system.
& the fluid does not have the same hydroscopic properties of brake fluid.
....so; you really don't need to change it very often.
PS fluid is cheap, so the easiest way to freshen it up is;
Draw as much fluid out of the reservoir as possible (a turkey baster works good) & top it up with fresh.
Repeat 2-3 more times over a couple of weeks & after the 3rd time you should see nice clear fluid in the reservoir.
for the brakes....
Brakes are brakes, ..basically you do them the same any car.
Draw the old fluid out of the reservoir, top up & start bleeding at the calipers.
There are many brake DIY postings here & all over the web if you want/need more detail.
Old 06-07-2008, 04:20 PM
2005 Infiniti G35
^ ok so brakes no problem, this is what I found on the power steering from some mustang forums.
Quote:
The return line is low pressure, and will usually just have a hose clamp on it where it connects to the pump. The high pressure line has molded connectors. To make it easier on your steering components and your tires, raise the front wheels off the ground slightly before you start (use jack stands). It is best to have a buddy to help you, so you don't have to make a dozen trips out from under the car and back. You don't want to let the reservoir go dry and get air in the system.
You can do this with the engine running while you turn the wheel left and right:
1. Remove hose and drain fluid.
2. Replace hose and top up the reservoir.
3. Start engine.
4. Slowly turn the wheels stop to stop, then back to straight ahead.
5. Stop engine
6. Repeat steps 1 through 5 as necessary, until the fluid you drain is clear.
ANOTHER POST
Quote:
Drain first:
Using s screwdriver, remove the loe-pressure hose from the pump (hose clamp).
AIM (you'll misss anyways) the hose at an oilpan to catch the fluid.
Drain ALL the oil from the housing.
Now flush:
Cap the housing with a rubber cap (plug the hole with something).
Add new fluid to top it off.
Idle the car while contantly adding fluid, while "peeing" out the removed hose into the drainpan.
When it runs clear, stop.
Reinstall the rubber hose, and top it off.
Run steering wheel lok-to-lok a few times to remove air bubbles from the rack, and check fluid level.
not too complicated.
__________________
centexvq.com
Old 06-09-2008, 12:10 PM
InTgr8r's Avatar
Administrator
2008 Infiniti G35
Piece of cake
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
