| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
Modded GTR owner in Japan gives report on his problems at high speed.
Quote:
This guy has the Japan version which I believe is set to go only up to 111 mph. I was just wondering if the US version which is limited to close to 160 mph will be more stable than the Japan version. http://www.gtr.co.uk/forum/upload/98...dangerous.html
__________________
06 G35 Sedan AT. Stock.W/Navi, Bluetooth,..etc...
I doubt the US version suspension/spring rate/shocks will be any different than the models offered around the world. Besides the top speed the only two other things diff in the US spec is obviously left hand drive and the front seats are a bit wider for our fAT AMERICAN A$$'S
interesting article non the less...seems like they found a crack in the GT-R's armor....but just like every first MY car this will get corrected for 2010 and so on
__________________
SFL G35Driver |
....... I've known about this for months~ why did it take people this long to figure it out? The GT-R is not stable enough above 150mph. The rear end kicks out all too eagerly when throttle is lifted or even reduced on a sweeper. If you run over some bumps at high speed the car will shoot off sideways even though the VDC will get you back on track. Turning on the Steering assist and traction control helps a bit. The car can do straight line at high speed perfectly fine, but when it comes to high speed corners some work needs to be done.
Quote:
the US version is not limited but to top gear redline which is at around 193 MPH |
thats ok... ill just cruise around 140 mph lol
__________________
EliteImportz.com |
Quote:
__________________
SFL G35Driver |
Quote:
that's awesome that you have, though, when did you get a chance to do this?
__________________
The strongest argument against democracy is a 5 minute conversation with your average voter. - Winston Churchill |
So...what does it feel like to drive the GTR above 130MPH??
__________________
05: IP G35 Coupe Sport: *Phase IIin Full Effect!* |
i saw dec55 over there. and i can't rule that out from my perspective.
if the unstable condition is caused by the 'cracking' of the ecu above 112mph, that would seriously explain why it happens at percisely that speed. and also why no reviewer experienced this phenomenon. the theory here is that the ecu was modified, and the ecu is no longer taking into account speed - and could even go as far as correcting for pitch at these higher speeds (because aero downforce is still being applied - but the car doesn't know it), and activating these controls to attempt to stabilize the vehicle for 112mph, and not 120mph. basically - the chip was modified to go faster... were all of the other factors corrected at each speed/pitch and yaw degree? or just speed? i think this is probable (and may explain why nissan doesn't think there is anything wrong). and this would explain why reviewers didn't see this, and why it's only being experienced by owners who bought vehicles that were governed at 112mph, and are traveling at speeds above that.
__________________
As always, 99% of the arguement against the OP was being done by those who don't own a GTR. No knocking anyone, just saying.
__________________
2005 G35 Coupe |
the only reason i support the ecu being part of the problem (cracked but not solved), is that we've already heard from existing g/z owners that when on a dyno, the results aren't 100% true, because the conditions of a dyno are not realistic, and the ecu was not designed to have acceleration at those speeds in that gear. so the feedback to the ecu was false, and therefor the output for those given rpms (which cannot - in real world situations occur), cannot be computed accurately.
this mulitplied by how many calculations are needed to maintain the 'electonic nannies' (as someone put it) may not have been accounted for. and maybe tuners like mine's were only looking for acheiving speed results and not worrying about trying to solve for other factors that were not part of that equation...
__________________
Okay, that's it. I'm not buying one.
__________________
2003 Emerald Mist/Graphite || Z/Coupe springs||Rays 19s||Stillen CAI w/CF tube || Skunk2 plenum spacer || 350z-Middy || Stillen sways || Philips/PIAA 6000K || nismo shiny things|| AMSOIL syn fluids |
lol!
__________________
Quote:
I just did it again last night to reconfirm. Without electronic aids the GT-R is definitely not the most stable car around high speed bends. I did it on the stock GT-R on Gran Turismo Prologue around Fuji Speedway, same thing on Daytona.
lol! that's awesome...
but that does lend itself to the suggestion (i'm not sure much credibility i'm going to offer sony) that the ecu, when not being used for stability would definitely make it less stable. that's like saying when i remove the fuse for my brakes, my abs stops working... wtf?
__________________
| Thread Tools | |
| Display Modes | Rate This Thread |
