MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 10-02-2008, 02:35 PM
Edmunds: Acura TL vs. S4 vs. 335 vs. G35 sedan
I always thought the suspension setup on the G35Sport is too conservative. They should reduce the ride height significantly, have more aggressive tire, and increase the track width. My 05 G35 rear end was moving around quite a bit until I lowered it, add spacer, and install better tires. Now the rear end is a bit more stable.
http://www.edmunds.com/insideline/do...ticleId=132226
Quote:
5th Place: To be honest, the Infiniti G35s didn't even get a second drive in the comparison. From the second corner of the first hot lap, it was painfully obvious that the heavy effort and lurching response of the clutch pedal (it turns out they're all like this), the heavy-effort shift action and an inability to keep its rear tires hooked up on anything less than a dead-straight piece of track kept the G35s from being able to put up a good fight. On this track, it required constant vigilance just to keep the G35s on the pavement.
__________________
2006 G35 Sedan 5AT - Revised Z springs/shocks - Stillen Sway Bar soft/soft - Stillen Z tube/CAI - 5/16 Iso Plenum Spacer - Coupe 19in. wheels
Old 10-02-2008, 02:48 PM
Why do they keep using the S4? Shouldn't it be A4?
__________________
'07 Obsidian Black G35 Sedan w/ Premium Package
Old 10-02-2008, 02:50 PM
Oh right and this is the Honda track... I remember seeing this somewhere. Probably an older thread.
__________________
Old 10-02-2008, 02:57 PM
There was a thread about two days ago on this same article.
__________________
2008 Ivory Pearl G35x
Old 10-09-2008, 12:30 PM
well they should've tested the g37 instead of the 35.
__________________
Stock: 03 Gcoupe 6mt Brembo pack.
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
