MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 05-07-2009, 06:59 PM
Location: Indiana. South Bend is in the north, North Judson is in the south, and French Lick isn't what you think it is.
Already recalled.
http://www.edmunds.com/insideline/do...ticleId=147626
__________________
Sold - 2003 G 6MT Coupe with mods
Sold - 2006 Lexus IS350 with mods
New - 2006 Audi A4 Quattro blk/blk mods duh!
When did it become cool to be stupid
Old 05-07-2009, 07:37 PM
2003 Infiniti G35 Coupe
Now thats just sad.. I didn't even know this car was released yet.
__________________
DO SOMETHING ABOUT IT!
Old 05-07-2009, 11:14 PM
Law to the Rence's Avatar
Lawww Dawwggg
2005 Infiniti G35
epic flunk
__________________
~ Cheers from Law
クルマのよろこびを。 日産です。
Old 05-08-2009, 10:03 AM
Kuneff's Avatar
Carpe Diem
1990 Ford Mustang
My Garage
Send a message via AIM to Kuneff
I just saw a thread yesterday where the front facia is cracking at the corner of headlights.
Quote from other forum...
Quote:
Originally Posted by 90talontsiawd View Post
[IMG]file:///C:/Users/Chris/AppData/Local/Temp/moz-screenshot.jpg[/IMG]Just some stuff popping up on internets
A Camaro5 forum member's posted a report with photos of the new Chevy Camaro with a crack on the front fascia's big upper brow reportedly attributed to a high-speed run. The cracks, which appear on both sides of the big upper brow of the nose of the new Camaro, were attributed to a high speed run — 155 MPH — earlier in the week. Here's the full report:
While I was doing the photo shoot on a 2010 Camaro SS this past Friday, we noticed some cracks forming at the upper corners of the grille. The tech that was assisting us during the shoot said that those happened during a top speed run earlier that week. The car achieved 155 mph, and apparently it lifted the upper part of the nose enough to form the cracks. I'm not sure if this problem has been addressed, or even mentioned before. Surely it can be something that GM can fix by adding more bracing perhaps, or a thicker nose molding. This 2010 SS was a production car, only a week old, so this concerns me. It might not be a good idea to do any high-speed runs in your new Camaro, at least until we understand the problem and how to fix it first.
Nevermind the high speed runs, maybe it'd also be a good idea to make sure you don't encounter any stiff winds. Match this nose-cone issue up with the slapped-on brake weights issue and Camaro crap-out we reported last week and you've got yourself a couple of cracks in the otherwise perfect fan-boy fascia of the Camaro. No pun intended. (Hat tip to Frankie and Rutledge!) [via Camaro5]
Forumites at Camaro5 have been collectively scratching their heads for a couple days, wondering why there appear to be two layers of lead wheel weights stuck onto their brake calipers. It's a mystery Charlie Brown! The confusion started when a poster uploaded an image of his new Camaro's Brembo calipers, on which were riding two rows of lead weights, normally affixed to the inside of a wheel rim to balance the tire. This led everyone with a Camaro to run outside to see it their mullet machine's also had the weights, which they do, at least on among the folks on the forum. GM has not answered to the confusion yet, but the leading theory is they were place on the caliper as a quick and dirty fix to alleviate brake squeal. From a physics perspective, this explanation is plausible, as resonant frequency is in large part determined by mass, and by changing the vibrating mass of the caliper with the weights, a troublesome squeal would be eliminated for a particular driving condition.
The trouble is if they're using normal brake weights, the heat cycling of the caliper will eventually cause the adhesive to fail and, if things get too serious on the track, the lead could actually melt. Though it's an odd issue and not really a big deal, we'll be keeping you in on the loop during Camaro brake-gate, though we recommend Camaro owners visit their local dealer and have their muffler bearings, blinker fluid, and piston-return springs checked out, just in case. Click here for the high-resolution image. Thanks for the tip Ethan! [Camaro5]
Maybe worse than the first Camaro wreck is the first Chevy Camaro breakdown. This "p**sy magnet" Bumblebee-yellow Camaro lost all electrical power and coasted to a stop with a scant 40 miles on the odometer.
The ecstatic new owner, a forum fan-girl by the name of BUMLB, was crushed when the car conked-out cruising through a parking lot at a leisurely 5 MPH, completely losing all electrical power, locking the gear selector and the key in the ignition. A flatbed towed the disabled car to a dealer where diagnosis found the cable running from the trunk mounted battery had frayed on the starter motor and grounded out, causing complete loss of power. A new cable running a different route will be installed at the dealer. Hopefully this isn't something we'll be seeing more of on other cars. [Camaro5] srsly
__________________
Education is the most powerful weapon which you can use to change the world
Old 05-08-2009, 10:09 AM
escobar929's Avatar
2005 Infiniti G35
Send a message via AIM to escobar929 Send a message via MSN to escobar929 Send a message via Yahoo to escobar929
wow, epic FAIL and i didnt even know they were out yet
__________________
Florida G Club | SFL G Club
Old 05-08-2009, 10:21 AM
IVRY PRL's Avatar
IP FREELY
2005 Infiniti G35 Coupe
Hahahaha... This is why they're going bankrupt. And you know what, the recall, I can let slide, because mistakes happen, but the brake weights? That sh1t is intentional. It's more of domestic auto makers arrogance about not having to sort out their engineering issues, and just slapping a band aid over them and releasing them to the general public.
__________________
MISAKI 美咲 | 2005 Ivory Pearl Coupe 6MT Sport | JIC FLT-A2s | 25mm Ichiba V2 Spacers | Megan v2 Test Pipes | Stillen Engine Damper | Tint | OEM Z-Tube | Gloss Black Roof Overlay | Satin Black Grille | 3000K Fogs
Old 05-08-2009, 10:30 AM
Hi-Tech_G's Avatar
Dream Big Achieve Greater
2004 Infiniti G35
Location: Pothole central and still ridin slammed...Beantown
Already.....Wow
__________________
VOID WARRANTYMy car sits like this /___\ and sneezes really loud...to my frenemies you know who you are....
Old 05-08-2009, 10:34 AM
Kuneff's Avatar
Carpe Diem
1990 Ford Mustang
My Garage
Quote:
Easy now buddy... You wound not want to be the captain of that rocket ship and have to slow that sumbitch down for an exit ramp, and start getting a wobble and shake from that caliper.... When your in control of a piece of rocket ship machinery like that... You gotta have your brakes in balance...
__________________
Old 05-08-2009, 10:38 AM
LightsOut's Avatar
SIETESG
never purchase first year production.
but wow already having issues, dang! and i was thinking about getting a camaro in the furture
__________________
OEM style made clean my way
4wisemen
Glance
Old 05-08-2009, 10:39 AM
HYDROERIC2003's Avatar
2003 Infiniti G35
Send a message via AIM to HYDROERIC2003 Send a message via Yahoo to HYDROERIC2003
its american made ! what do u expect ?
Old 05-08-2009, 10:47 AM
i remember when the c5 corvette came out.. it also had a quick re-call. something to do with the steering rods. these things sometimes happen. u've got a network of suppliers all being strapped for the lowest price. there's bound to be some cut corners. are u telling me that nissan/infiniti doesn't cut corners? please.
but i gotta admit.. n.a. auto makers seem to be notorious for this stuff.
__________________
bye bye '05 G35 coupe -> 2008 - BMW E93 335i - White/Red -6MT - Fully Loaded - 35% - M-Technik
Old 05-08-2009, 10:55 AM
WhosUrBuddiee's Avatar
2004 INFINITI G35 Coupe
That is actually pretty funny.
__________________
National G Club G37S Bone Stock
Old 05-08-2009, 11:07 AM
+1 on first production cars, there's always gonna be re-calls
the pressure of releasing the car on a timely manner, they gotta try to get all the kinks out, but not all of them...
+1 on the Cutting Corners, what manufacturer doesnt cut corners to save time.money
i wonder what other issues will come up, only time will reveal...
Thanks for posting, ill let my buddy know of the "potential" problems.
__________________
03 DP coupe/ Sport Bumper/ AXIS 7mod 20s/ Gstechs/ wtb: 15 &20 mm spacers
Old 05-08-2009, 11:26 AM
O HELLA OEM's Avatar
Im Going All Impul.
Send a message via AIM to O HELLA OEM
damnn
__________________
Ohio G Club Member
**Ninja**
....Nissan Skyline 350GT....
Old 05-08-2009, 12:09 PM
That is why a new car comes with a warrenty. Still very nice looking.
__________________
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
