MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > The Lounge OT > The Lounge (Off Topic) > Other Cars
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 09-29-2005, 07:58 PM
Gangster Member
What makes M3 so much faster than the G35?
They both weigh about the same, M3 has 35 more hp, a little more trq, but the 0-60 is an insanely fast 4.8, to a g35 5.6. Is it just the brilliant BMW enginnering?
Old 09-29-2005, 07:59 PM
bore size and piston rod...its quicker to displace
Old 09-29-2005, 08:00 PM
gtr proto test driver
could a g35 with 35+ HP and a little more trq beat an M3?
Old 09-29-2005, 08:06 PM
Quote:
Probably not, but it'll hang or be even...
Finiti, feel free to chime in.
Old 09-29-2005, 08:09 PM
3.2-liter dual overhead cam (DOHC), 24-valve inline 6-cylinder engine with Double-VANOS “steplessly” variable valve timing
6 individual throttles, electronically controlled (drive-by-wire), with M Dynamic Driving Control (throttle control)
Digital Motor Electronics (DME) with on-board diagnostics
Distributorless electronic ignition system
Truly amazing for a car with .3 less displacement than the G35. But I bet some of this crap has to do with it as well...
Old 09-29-2005, 08:11 PM
the g35 needs more rear end gear to quicken the accelleration from a standstill.
That is just for starters.
__________________
Twin Turbo Sedan - DIY it!!!!!
Old 09-29-2005, 08:13 PM
Gangster Member
^^^^ looked that up really quick on the internet
Old 09-29-2005, 08:18 PM
http://www.bmwusa.com/vehicles/M/M3Coupe/features.htm
Old 09-29-2005, 08:19 PM
Rollin On Dubz
Send a message via AIM to MikeyMike
There was a discussion about "BMW horsepower" on this forum a few months ago.
Basically...the conclusion was although, for example, a 330 had similar weight to a G35. The G35 had more horsepower, but the BMW 330 was still just as fast.
Why? The BMW has superior engineering and doesn't lose as much HP at the wheels. Because we all know there is HP the engine produces...and then a smaller amount of HP thats gets to the crank...and even smaller that gets to the wheels.
In conclusion, BMW's don't lose HP to the wheels as much as other car's do...so they they can have engines that produce less HP than comparable cars..but still be just as fast because of efficient powertrain designs.
The Germans at BMW are some mad friggin scientists if you ask me...but that m3's engine is still a doozy...heeard a lot about those things blowing, even on the later m3's.
Old 09-29-2005, 08:27 PM
Send a message via AIM to chilibowl
Even though m3's are pretty quick, they still sound like ****. A g35's exhaust note makes the m3 sound like a Geo metro.
Old 09-29-2005, 08:28 PM
Gangster Member
Quote:
i dont know man i like the sound of the M3
Old 09-29-2005, 08:29 PM
Send a message via AIM to 636Racer
Quote:
If the car was continually pushed towards it's limits, I would expect so. Same goes with the VQ if continually pushed. I'm pretty sure there'd be some kind of failure.
__________________
Get UpRev'd at MunkyWurks PH: (808)848-8794 (Refer 636Racer)
2008 Nissan Titan SE KC SWB 4x2
2004 Infiniti G35 Coupe
Old 09-29-2005, 08:32 PM
with the m3s steeper trans geasring and rear gearing, they have a
14% mechanical advantage in 1st gear
11% advantage in 2nd gear
5% in 3rd gear
4th gear is about even.
__________________
Old 09-29-2005, 08:33 PM
A 330? Did you remove two cylinders from your G?
__________________
LS '05 G35 Coupe 6MT 19" stock rims.
Old 09-29-2005, 08:45 PM
The 3.92 gears would give you about 10-11% more mechanical advantage than with the current 3.54 rear gears.
__________________
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
